Re: THE R5 P7 THREAD FOR EVERYONE
[Re: DemonDust]
#1737296
01/24/15 04:55 AM
01/24/15 04:55 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Looks nice, why such a big oil tank? I'll let you know right now from experience the tires you have on that car now. Don't hook for sh!t. You'll be lucky to run low 10s with them, even launching from an idle. The pro ETs are the way to go
I think he'll be okay with that tire. He has A LOT of suspension to play with
[Re: mopartony]
#1737311
01/24/15 11:33 PM
01/24/15 11:33 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
That's a beautiful car, Robert sent me pics every step of his build.
It started as a BIW challenger.
[Re: DemonDust]
#1737316
01/25/15 05:56 AM
01/25/15 05:56 AM
Posts: 2,128 sweden
sshemi
sweden
I'm running a 904, 7200 stall. Mono leafs and cal tracs. DA Viking shocks. I run clocks off so I don't care to share much more. Currently rebuilding my engine, it was getting tired after 5 years.
Hoping to get the suspension dialed in with the new build and run KOTS and some grudge racing.
When you rebuild it will you get new pistons with normal rings, or go with the super expensive rings?
Im pretty sure when my motor needs rebuild i will get a set of custom pistons with normal rings grooves. Either get them for boost or NOS.
[Re: sshemi]
#1737317
01/25/15 08:48 AM
01/25/15 08:48 AM
Posts: 486 IL
knyech1
IL
I'm taking on the daunting task of building one of these up from a virgin block and a few parts (which everyone says I shouldn't do. I will be putting in a more normal piston and ring package with lower comp for a big turbo.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
[Re: knyech1]
#1737318
01/25/15 09:00 AM
01/25/15 09:00 AM
Posts: 35 Down under
OUTLAW565
Down under
Sounds good mate. What size turbo are you going to use? Blow through or efi? The main and big end journals are a bit small.
[Re: sshemi]
#1737319
01/25/15 12:35 PM
01/25/15 12:35 PM
DemonDust
Menomonee Falls
I'm currently undecided on a block. I may go with an aluminum block, I'm waiting to hear back on what the specs of it are. If it is usable for what I want, I will go with that. Even if I use my current block or the other one I have laying here which are both iron. I would use a normal ring pack .043,.043, 3mm. Even if I used my old pistons, Eric at Rebco can open up the ring lands for under $250 for the whole set, so cost effective rings can be used. I've got about 10 sets of new and used pistons so no matter which way I go it'll get a more normal ring pack.
[Re: DemonDust]
#1737320
01/25/15 01:47 PM
01/25/15 01:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since these are normally a very high reving engine and I assume a fairly short stroke... whats the longest arm you can fit in the block.. and of course.. can you find a long arm crank
[Re: knyech1]
#1737323
01/25/15 03:52 PM
01/25/15 03:52 PM
DemonDust
Menomonee Falls
I've seen a 3.73? and a 3.800. The guy that had them wanted stupid money for them so I passed since they were used. I called Winberg and they can make them in the 3k range. I've seen around 8-10, 3.55-3.58 on eBay. They usually went for a decent price, but at the time I wasn't looking to buy. I think a 4" is possible but you'd have to open up the cam tunnel for clearance.
[Re: DemonDust]
#1737324
01/25/15 05:12 PM
01/25/15 05:12 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
The most stroke I have seen on EBay was 3.300. There was an engine for sale with more stroke. I missed the deal. It was a 388.
I started looking at a later date than R5P7 duster did. Message is they are gone.
[Re: DemonDust]
#1737330
01/26/15 12:39 PM
01/26/15 12:39 PM
Leon441
Lynchburg, VA
EEI advertises iron block combos at 414".
[Re: mopartony]
#1737331
01/26/15 04:41 PM
01/26/15 04:41 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
If you look at Jeremy Combs fb page you can see one of manifolds cut in half.. Jeremy builds some of the baddest engines out their and why Extreme is his company name .. And yes BIG is better
[Re: OUTLAW565]
#1737333
01/31/15 10:21 PM
01/31/15 10:21 PM
Leon441
Lynchburg, VA
I run MSD. But, I'm using nothing from the original setup. I run a belt drive distributor and a crank trigger.
With the NASCAR distributor any MSD 6 or 7 series ignition will work.
[Re: OUTLAW565]
#1737334
02/01/15 04:29 PM
02/01/15 04:29 PM
Posts: 41 PA
R5P7 Bantam
PA
What ignitions are you blokes using on these engines?
I use an MSD 7AL-3 with a Pro Power coil. I use the Crane distributor as well. This dist. has 3 wires per side. Two are the signal wires from the MSD and the third (red one) need to have power 12v supplied to it. I believe the crane unit is the best unit available. There's no reluctor (sp?) or pickup like typical distributors.
Mike
[Re: Dave W]
#1737336
02/01/15 06:02 PM
02/01/15 06:02 PM
Leon441
Lynchburg, VA
Race parts liquidators says he has some.
Of course I had to sleeve mine and support the crack for insurance.
[Re: DemonDust]
#1737342
02/02/15 07:47 PM
02/02/15 07:47 PM
Leon441
Lynchburg, VA
Ryan is building a cast iron XR2 Ritter. It is not a R5P7. It's a XR2P7. LOL
But seriously that's what it will be when he gets it done.
[Re: Leon441]
#1737343
02/04/15 11:49 AM
02/04/15 11:49 AM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
I am using 7al-2 and pro power coil. "stock" msd dist.
Best run so far with 2845lbs 9.29s. 727 and leafs. car is now torn apart, 9" and 4-links are coming in few months.
-1965 Valiant 9.03s 358cu.in R5P7-
[Re: Leon441]
#1737344
02/04/15 01:50 PM
02/04/15 01:50 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Any issue with that block? Matt
[Re: Leon441]
#1737346
02/05/15 04:40 PM
02/05/15 04:40 PM
MattW
Ontario Canada
YES
Small stuff or Big stuff?
Man oh man if Ritter can get them straighten out he will make some money
Thx
[Re: MattW]
#1737347
02/05/15 10:35 PM
02/05/15 10:35 PM
Leon441
Lynchburg, VA
Machine work with dull tools. One guy installed head studs and found the holes were not cut and threaded square.
We can only hope these blocks get better.
Done correctly should make a great peice.
[Re: Leon441]
#1737348
02/06/15 10:10 AM
02/06/15 10:10 AM
DemonDust
Menomonee Falls
It always boggles my mind that a machine shop can't do a job that seems pretty straight forward. And with all the 5 axis stuff they have these days, to index, locate holes, and be able to make a program should not be an issue at all.
Even something as simple as brake caliper brackets I bought from aerospace where machined almost .100 out of square. Of course they made me new ones at no charge, but WTF?
[Re: DemonDust]
#1737349
02/07/15 12:20 AM
02/07/15 12:20 AM
Leon441
Lynchburg, VA
Let's hope these will be perfect
[Re: DemonDust]
#1737352
02/07/15 12:59 AM
02/07/15 12:59 AM
Leon441
Lynchburg, VA
No plans for doing 904 stuff. I am 4 months into this deal. Holidays, trade shows, change of ownership. I will see this deal through. And we will see what the new ownership does. QuickTime says things should be better with MSD owning them. Time will tell.
[Re: Leon441]
#1737353
02/07/15 01:20 AM
02/07/15 01:20 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
MSD has come out the other side of their difficulties OK then?
Kevin
[Re: Twostick]
#1737354
02/22/15 01:32 AM
02/22/15 01:32 AM
Leon441
Lynchburg, VA
Bells are done. Flexplates also. Need spacer and converter pilot.
[Re: Leon441]
#1737355
02/22/15 01:33 AM
02/22/15 01:33 AM
Leon441
Lynchburg, VA
Flexplate
