Re: THE R5 P7 THREAD FOR EVERYONE
[Re: OUTLAW565]
#1737333
01/31/15 10:21 PM
01/31/15 10:21 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I run MSD. But, I'm using nothing from the original setup. I run a belt drive distributor and a crank trigger.
With the NASCAR distributor any MSD 6 or 7 series ignition will work.
[Re: OUTLAW565]
#1737334
02/01/15 04:29 PM
02/01/15 04:29 PM
Posts: 41 PA
R5P7 Bantam
PA
What ignitions are you blokes using on these engines?
I use an MSD 7AL-3 with a Pro Power coil. I use the Crane distributor as well. This dist. has 3 wires per side. Two are the signal wires from the MSD and the third (red one) need to have power 12v supplied to it. I believe the crane unit is the best unit available. There's no reluctor (sp?) or pickup like typical distributors.
Mike
[Re: Dave W]
#1737336
02/01/15 06:02 PM
02/01/15 06:02 PM
Leon441
Lynchburg, VA
Race parts liquidators says he has some.
Of course I had to sleeve mine and support the crack for insurance.
[Re: DemonDust]
#1737342
02/02/15 07:47 PM
02/02/15 07:47 PM
Leon441
Lynchburg, VA
Ryan is building a cast iron XR2 Ritter. It is not a R5P7. It's a XR2P7. LOL
But seriously that's what it will be when he gets it done.
[Re: Leon441]
#1737343
02/04/15 11:49 AM
02/04/15 11:49 AM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
I am using 7al-2 and pro power coil. "stock" msd dist.
Best run so far with 2845lbs 9.29s. 727 and leafs. car is now torn apart, 9" and 4-links are coming in few months.
-1965 Valiant 9.03s 358cu.in R5P7-
[Re: Leon441]
#1737344
02/04/15 01:50 PM
02/04/15 01:50 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Any issue with that block? Matt
[Re: Leon441]
#1737346
02/05/15 04:40 PM
02/05/15 04:40 PM
MattW
Ontario Canada
YES
![](/ubbthreads/images/graemlins/bawling.gif)
Small stuff or Big stuff?
Man oh man if Ritter can get them straighten out he will make some money
Thx
[Re: MattW]
#1737347
02/05/15 10:35 PM
02/05/15 10:35 PM
Leon441
Lynchburg, VA
Machine work with dull tools. One guy installed head studs and found the holes were not cut and threaded square.
We can only hope these blocks get better.
Done correctly should make a great peice.
[Re: Leon441]
#1737348
02/06/15 10:10 AM
02/06/15 10:10 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
It always boggles my mind that a machine shop can't do a job that seems pretty straight forward. And with all the 5 axis stuff they have these days, to index, locate holes, and be able to make a program should not be an issue at all.
Even something as simple as brake caliper brackets I bought from aerospace where machined almost .100 out of square. Of course they made me new ones at no charge, but WTF?
[Re: DemonDust]
#1737349
02/07/15 12:20 AM
02/07/15 12:20 AM
Leon441
Lynchburg, VA
Let's hope these will be perfect
[Re: DemonDust]
#1737352
02/07/15 12:59 AM
02/07/15 12:59 AM
Leon441
Lynchburg, VA
No plans for doing 904 stuff. I am 4 months into this deal. Holidays, trade shows, change of ownership. I will see this deal through. And we will see what the new ownership does. QuickTime says things should be better with MSD owning them. Time will tell.
