B body dana #1732399
01/17/15 09:24 PM
01/17/15 09:24 PM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
Can any one help me on this, bought a dana rear thought it was for a b body. Spring perches were too far apart to set on springs putting it in a 68 roadrunner. The measurement drum to drum is correct for 68 b body 60 inches. Would anyone know what its out of? It should work for 68 b body can I just move the spring perches in?????????????????
Re: B body dana [Re: fpmopar] #1732400
01/17/15 09:50 PM
01/17/15 09:50 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Does it have pads for the pinion snubber? If so, somebody already moved the perches (they should be 44" center-to-center). Look for the BOM number stamped in the right axle tube to see its original application.
Re: B body dana [Re: fpmopar] #1732401
01/18/15 03:19 PM
01/18/15 03:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Whats the distance between the perches measured center to center?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: B body dana [Re: fpmopar] #1732402
01/19/15 12:51 AM
01/19/15 12:51 AM
Lebanon, OH
Brad4406 Offline
Brad4406  Offline
Lebanon, OH
If it is the correct width from drum to drum, cut the perches off and move them in. Be sure to set the pinion angle before welding the perches to the housing.
Re: B body dana [Re: fpmopar] #1732403
01/19/15 09:30 AM
01/19/15 09:30 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Try here (it will show where to find the BOM and has a decoder)-
http://www.differentials.com/technical-help/differential-identification
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
