Re: B body dana
[Re: fpmopar]
#1732400
01/17/15 09:50 PM
01/17/15 09:50 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does it have pads for the pinion snubber? If so, somebody already moved the perches (they should be 44" center-to-center). Look for the BOM number stamped in the right axle tube to see its original application.
Re: B body dana
[Re: fpmopar]
#1732401
01/18/15 03:19 PM
01/18/15 03:19 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Whats the distance between the perches measured center to center?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: B body dana
[Re: fpmopar]
#1732402
01/19/15 12:51 AM
01/19/15 12:51 AM
Posts: 70 Lebanon, OH
Brad4406
Lebanon, OH
If it is the correct width from drum to drum, cut the perches off and move them in. Be sure to set the pinion angle before welding the perches to the housing.
