Could use some advice on locking tailgate mechanism #1731450
01/16/15 06:16 PM
01/16/15 06:16 PM
Northeast
V
VincentVega Offline OP
V
Northeast
It appears I will be moving across the country to our nation's heartland. And from a nice, secure rural home to a semi-city-ish duplex.
I'd like to install a locking tailgate mechanism on my 05 Ram 1500 (6'4" bed). I also read something about putting hoseclamps (loosely, I guess?) around the tailgate hinge pivots to help prevent people from ripping the gate out and stealing it.
So, I'd like to hear opinions on that. I love OEM stuff, and I did a little shopping, but I didn't turn up much on an OEM manual latch mechanism that accepts a key. Being able to use the key fob for the gate is the last thing on my mind. I see a Bully brand handle with key, it's less than 30 bucks, but people say it isn't too rugged and I question the longevity
I'd also like opinions on some kind of locking tonneau cover that would work along with this, to help protect my junk on the 2 day driving trip out there.
Bear in mind I am on a budget
thanks for any suggestions
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Could use some advice on locking tailgate mechanism [Re: VincentVega] #1731451
01/16/15 06:39 PM
01/16/15 06:39 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
You likely have lots of good options as your truck is relatively New.
Here is one type to consider.
Master Tailgate Lock
There are competing brands that are similar. The complaint on these is that many of the components are plastic. The best any security can do is slow a thief down or discourage them enough to move on.
There are also quite a few choices of Locking Tailgate Handles. I would give those extra consideration. They cost quite a bit more, but should be worth it.
Re: Could use some advice on locking tailgate mechanism [Re: D_C] #1731452
01/16/15 06:51 PM
01/16/15 06:51 PM
D_C Offline
D_C  Offline
Like this:
Re: Could use some advice on locking tailgate mechanism [Re: D_C] #1731453
01/16/15 06:55 PM
01/16/15 06:55 PM
Northeast
V
V
Northeast
Like this:
I would love that.
Re: Could use some advice on locking tailgate mechanism [Re: VincentVega] #1731454
01/16/15 07:22 PM
01/16/15 07:22 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
they're both relatively inexpensive, compared to the price of a new tailgate. get them both.
Re: Could use some advice on locking tailgate mechanism [Re: Golden-Arm] #1731455
01/16/15 07:28 PM
01/16/15 07:28 PM
Northeast
V
V
Northeast
anyone like any particular brands? I've got zero experience on this end of things
Re: Could use some advice on locking tailgate mechanism [Re: VincentVega] #1731456
01/16/15 09:41 PM
01/16/15 09:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: Could use some advice on locking tailgate mechanism [Re: VincentVega] #1731457
01/17/15 04:31 AM
01/17/15 04:31 AM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
I put a bully tailgate lock and extang solid fold tonneau cover on the 2000 Dakota my daughter drove to college... she never had any one break in to her truck, close the cover, shut and lock tailgate. In the 4 and half years I have never had to adjust the lock. I have seen around 10 college girls standing on the cover at a larcross games with no damage, I did replace 1x2 inch of foam to stop a very small water leak, it was $5 fix from advance....
Bully lock
http://www.bullytruck.com/Tailgatelock.htm
Extang Solid Fold
http://tonneaucoversworld.com/extang-solid-fold.aspx
The cover is not cheep. I could install it by myself, my daughter could install and remove it with the help of one friend.
If you just need it to for a 2 day drive... I would think about a covering the load and driving, or try to find a used cap cheep, and then resale it once I got to where I was gong/
Re: Could use some advice on locking tailgate mechanism [Re: RODHALL] #1731458
01/17/15 03:05 PM
01/17/15 03:05 PM
Northeast
V
V
Northeast
Thanks, Rodhall
Re: Could use some advice on locking tailgate mechanism [Re: VincentVega] #1731459
01/20/15 05:03 PM
01/20/15 05:03 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I'll second the Bully locking handle. That was the very first thing I changed on my 07 when It was new. Still works just like it did.
Re: Could use some advice on locking tailgate mechanism [Re: NITROUSN] #1731460
01/20/15 06:25 PM
01/20/15 06:25 PM
N.E. Ohio
K
KillerBee Online content
KillerBee  Online Content
K
N.E. Ohio
http://www.popandlock.net/
I put the electric pop and lock on my 2004 2500 Ram 7-8 years and it has worked perfectly.
Install was easy.
Remove access cover on tailgate and install the unit at the tail gate rod mechanism, run the wire out a hole in the bottom of the tail gate, under the truck and through a grommet in the firewall to the electric door lock wire.
Locks and unlocks the tailgate with the power door locks.
Would buy another.
Re: Could use some advice on locking tailgate mechanism [Re: KillerBee] #1731461
01/20/15 09:32 PM
01/20/15 09:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Got a bully locking handle for my 2003 Ram and it's as sturdy as the factory one plus it's a snap to install.
Re: Could use some advice on locking tailgate mechanism [Re: stumpy] #1731462
01/20/15 11:22 PM
01/20/15 11:22 PM
Northeast
V
V
Northeast
Thanks! I really appreciate the comments
