Could use some advice on locking tailgate mechanism
#1731450
01/16/15 06:16 PM
01/16/15 06:16 PM
Posts: 1,106 Northeast
VincentVega
Northeast
It appears I will be moving across the country to our nation's heartland. And from a nice, secure rural home to a semi-city-ish duplex.
I'd like to install a locking tailgate mechanism on my 05 Ram 1500 (6'4" bed). I also read something about putting hoseclamps (loosely, I guess?) around the tailgate hinge pivots to help prevent people from ripping the gate out and stealing it.
So, I'd like to hear opinions on that. I love OEM stuff, and I did a little shopping, but I didn't turn up much on an OEM manual latch mechanism that accepts a key. Being able to use the key fob for the gate is the last thing on my mind. I see a Bully brand handle with key, it's less than 30 bucks, but people say it isn't too rugged and I question the longevity
I'd also like opinions on some kind of locking tonneau cover that would work along with this, to help protect my junk on the 2 day driving trip out there.
Bear in mind I am on a budget
thanks for any suggestions
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Could use some advice on locking tailgate mechanism
[Re: VincentVega]
#1731451
01/16/15 06:39 PM
01/16/15 06:39 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
You likely have lots of good options as your truck is relatively New. Here is one type to consider. Master Tailgate Lock There are competing brands that are similar. The complaint on these is that many of the components are plastic. The best any security can do is slow a thief down or discourage them enough to move on. There are also quite a few choices of Locking Tailgate Handles. I would give those extra consideration. They cost quite a bit more, but should be worth it.
[Re: Golden-Arm]
#1731455
01/16/15 07:28 PM
01/16/15 07:28 PM
VincentVega
Northeast
anyone like any particular brands? I've got zero experience on this end of things
[Re: VincentVega]
#1731457
01/17/15 04:31 AM
01/17/15 04:31 AM
Posts: 2,930 Waynesboro PA 17268
RODHALL
Waynesboro PA 17268
I put a bully tailgate lock and extang solid fold tonneau cover on the 2000 Dakota my daughter drove to college... she never had any one break in to her truck, close the cover, shut and lock tailgate. In the 4 and half years I have never had to adjust the lock. I have seen around 10 college girls standing on the cover at a larcross games with no damage, I did replace 1x2 inch of foam to stop a very small water leak, it was $5 fix from advance.... Bully lock http://www.bullytruck.com/Tailgatelock.htmExtang Solid Fold http://tonneaucoversworld.com/extang-solid-fold.aspxThe cover is not cheep. I could install it by myself, my daughter could install and remove it with the help of one friend. If you just need it to for a 2 day drive... I would think about a covering the load and driving, or try to find a used cap cheep, and then resale it once I got to where I was gong/
[Re: NITROUSN]
#1731460
01/20/15 06:25 PM
01/20/15 06:25 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
http://www.popandlock.net/
I put the electric pop and lock on my 2004 2500 Ram 7-8 years and it has worked perfectly.
Install was easy. Remove access cover on tailgate and install the unit at the tail gate rod mechanism, run the wire out a hole in the bottom of the tail gate, under the truck and through a grommet in the firewall to the electric door lock wire.
Locks and unlocks the tailgate with the power door locks.
Would buy another.
[Re: stumpy]
#1731462
01/20/15 11:22 PM
01/20/15 11:22 PM
VincentVega
Northeast
Thanks! I really appreciate the comments
