Re: hemi k frames
[Re: RAH]
#1726227
01/10/15 10:50 AM
01/10/15 10:50 AM
Posts: 1,106 CANADA
Desmond
CANADA
you need to use the '70 steering box and column
"Been spending all my nights on the internet, looking for a clue that I ain't found yet, just a bunch of Mopars, guitars and other s#*t i can't buy." - Sturgill Simpson
Re: hemi k frames
[Re: Desmond]
#1726228
01/10/15 10:53 AM
01/10/15 10:53 AM
Posts: 1,385 Az
69hemibeep
Az
Didn't they use a different sway bar set up?
1969 Hemi Roadrunner 2nd owner
Re: hemi k frames
[Re: Desmond]
#1726230
01/10/15 12:01 PM
01/10/15 12:01 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Not true.
Re: hemi k frames
[Re: 69hemibeep]
#1726231
01/10/15 12:03 PM
01/10/15 12:03 PM
JohnRR
U.S.S.A.
Yes they did and it only requires drilling holes for the swaybar mounts if going from a 70 to 68 , going 68 to 70 won't work because the 70 swaybar passes thru the K member.
Re: hemi k frames
[Re: RAH]
#1726233
01/10/15 12:44 PM
01/10/15 12:44 PM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
There is also a difference in the skid plate.
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
Re: hemi k frames
[Re: Desmond]
#1726235
01/10/15 01:13 PM
01/10/15 01:13 PM
JohnRR
U.S.S.A.
Not true.
Well, that's what I had to do - the angle was completely off using the '68-'69 set up I had...
Then you got one that missed QC checks because the steering box angle is the same 66-7. Also a 70 column is different than 68-69 so I'm curious what you did there ... 68-69 ignition is in the dash , 70 in the column.
Re: hemi k frames
[Re: BS27R1B]
#1726236
01/10/15 01:15 PM
01/10/15 01:15 PM
JohnRR
U.S.S.A.
I forgot about that , 68 has a MAN'S skidplate , 70 has a something about the thickness of tinfoil.
Re: hemi k frames
[Re: NITROUSN]
#1726238
01/10/15 05:17 PM
01/10/15 05:17 PM
JohnRR
U.S.S.A.
Maybe you had a 70 E body Hemi K-frame???..
Probably ...
Re: hemi k frames
[Re: RAH]
#1726240
01/10/15 08:37 PM
01/10/15 08:37 PM
Posts: 467 Coon Valley, WI
megaparts
Coon Valley, WI
does anyone know if a 1970 HEMI k frame will go into a 1968 roadrunner with minimal or no modifications? what needs to be modified or changed?
Bob if you have questions give my dad a call He knows them inside and out. I know the skid plate and sway bar are different and am pretty sure that is it. If the one you have is an original as Scott said you will come out ahead selling it and getting a correct one.
Re: hemi k frames
[Re: JohnRR]
#1726241
01/11/15 12:52 AM
01/11/15 12:52 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Probably ...
I agree,isn't the steering box at a different angle on the E-body K-frame?
Re: hemi k frames
[Re: RTSrunner]
#1726242
01/11/15 02:13 AM
01/11/15 02:13 AM
JohnRR
U.S.S.A.
Probably ...
Yes it is .
