hemi k frames #1726226
01/10/15 10:07 AM
01/10/15 10:07 AM
sw chicago
RAH Offline OP
RAH  Offline OP
sw chicago
does anyone know if a 1970 HEMI k frame will go into a 1968 roadrunner with minimal or no modifications? what needs to be modified or changed?
Re: hemi k frames [Re: RAH] #1726227
01/10/15 10:50 AM
01/10/15 10:50 AM
CANADA
Desmond Offline
Desmond  Offline
CANADA
you need to use the '70 steering box and column
"Been spending all my nights on the internet, looking for a clue that I ain't found yet, just a bunch of Mopars, guitars and other s#*t i can't buy." - Sturgill Simpson
Re: hemi k frames [Re: Desmond] #1726228
01/10/15 10:53 AM
01/10/15 10:53 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Didn't they use a different sway bar set up?
1969 Hemi Roadrunner 2nd owner
Re: hemi k frames [Re: 69hemibeep] #1726229
01/10/15 11:55 AM
01/10/15 11:55 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd sell it and buy a correct one for the 68. You should come out money ahead.
Re: hemi k frames [Re: Desmond] #1726230
01/10/15 12:01 PM
01/10/15 12:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not true.
Re: hemi k frames [Re: 69hemibeep] #1726231
01/10/15 12:03 PM
01/10/15 12:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes they did and it only requires drilling holes for the swaybar mounts if going from a 70 to 68 , going 68 to 70 won't work because the 70 swaybar passes thru the K member.
Re: hemi k frames [Re: JohnRR] #1726232
01/10/15 12:34 PM
01/10/15 12:34 PM
sw chicago
RAH Offline OP
RAH  Offline OP
sw chicago
thanks much for all your advise bob h 708 687 1187
Re: hemi k frames [Re: RAH] #1726233
01/10/15 12:44 PM
01/10/15 12:44 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
There is also a difference in the skid plate.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: hemi k frames [Re: JohnRR] #1726234
01/10/15 12:55 PM
01/10/15 12:55 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
Not true.
Well, that's what I had to do - the angle was completely off using the '68-'69 set up I had...
Re: hemi k frames [Re: Desmond] #1726235
01/10/15 01:13 PM
01/10/15 01:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not true.
Then you got one that missed QC checks because the steering box angle is the same 66-7. Also a 70 column is different than 68-69 so I'm curious what you did there ... 68-69 ignition is in the dash , 70 in the column.
Re: hemi k frames [Re: BS27R1B] #1726236
01/10/15 01:15 PM
01/10/15 01:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I forgot about that , 68 has a MAN'S skidplate , 70 has a something about the thickness of tinfoil.
Re: hemi k frames [Re: Desmond] #1726237
01/10/15 02:01 PM
01/10/15 02:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe you had a 70 E body Hemi K-frame???..
Re: hemi k frames [Re: NITROUSN] #1726238
01/10/15 05:17 PM
01/10/15 05:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Probably ...
Re: hemi k frames [Re: JohnRR] #1726239
01/10/15 08:22 PM
01/10/15 08:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Go to the MegaParts website and look at the pictures.
Re: hemi k frames [Re: RAH] #1726240
01/10/15 08:37 PM
01/10/15 08:37 PM
Coon Valley, WI
megaparts Offline
megaparts  Offline
Coon Valley, WI
Bob if you have questions give my dad a call He knows them inside and out. I know the skid plate and sway bar are different and am pretty sure that is it. If the one you have is an original as Scott said you will come out ahead selling it and getting a correct one.
Re: hemi k frames [Re: JohnRR] #1726241
01/11/15 12:52 AM
01/11/15 12:52 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Probably ...
I agree,isn't the steering box at a different angle on the E-body K-frame?
Re: hemi k frames [Re: RTSrunner] #1726242
01/11/15 02:13 AM
01/11/15 02:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Probably ...
Yes it is .
Re: hemi k frames [Re: JohnRR] #1726243
01/11/15 04:54 AM
01/11/15 04:54 AM
Years ago I swapped a 1968 RR Hemi motor and tranny with the K member into a 1969 GTX, we ended up wrecking that car going to the races after hitting a big wild dog The owner bought a R/T 440 1970 Challenger out of a wrecking yard in Los Angles and I swapped that K member, motor and tranny into the Challenger I think I took the steering colmum apart and had a extension welded onto it to make it fit the standard steering box out of the RR To many years ago, we never had any issues that I remember other than NHRA raisning a fuss about the sway bar and how I had to beat the 1968 K member up to make the 1970 E body sway bar fit in it
Re: hemi k frames [Re: JohnRR] #1726244
01/12/15 12:08 PM
01/12/15 12:08 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
Not true.
Never touched the column inside the car, had to modify it as it hooked to the steering gear in the engine compartment. Coulda been an e-body K, yeah. Was a while ago...
