what paint is used when stamping KV fuel rubber hose?? #1721410
01/04/15 02:42 PM
01/04/15 02:42 PM
Sweden
71redcuda Offline OP
Sweden
Im about to do some stamping on a rubber hose, want the paint to look like the rest of the KV factory hoses.
Anyone know what paint to use?
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 71redcuda] #1721411
01/04/15 06:01 PM
01/04/15 06:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It's an ink....not paint
Re: what paint is used when stamping KV fuel rubber hose?? [Re: gtx6970] #1721412
01/04/15 06:24 PM
01/04/15 06:24 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
And....and....and.....
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 71redcuda] #1721413
01/04/15 06:34 PM
01/04/15 06:34 PM
Valencia, CA
K
kpkube Offline
kpkube  Offline
K
Valencia, CA
I think silk screening inks are used...
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 6PakBee] #1721414
01/04/15 06:35 PM
01/04/15 06:35 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The hoses are being reproduced, offering such detail might prove counter productive to making future sales.
Re: what paint is used when stamping KV fuel rubber hose?? [Re: ScottSmith_Harms] #1721415
01/04/15 07:12 PM
01/04/15 07:12 PM
Sweden
Sweden
This hose is not reproduced...
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 71redcuda] #1721416
01/04/15 07:15 PM
01/04/15 07:15 PM
Sweden
Sweden
another, check the line on the hose
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 71redcuda] #1721417
01/04/15 07:18 PM
01/04/15 07:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Oh trust me, I've noticed! MOST reproduction hoses (even those stamped "correctly") vary a little (or in some cases A LOT) from original. Plenty of room for improvement in this category.
Re: what paint is used when stamping KV fuel rubber hose?? [Re: ScottSmith_Harms] #1721418
01/04/15 07:56 PM
01/04/15 07:56 PM
New Jersey Bada Bing
bremotorsports Offline
I am already in process of laying the groundwork for properly reproducing the "KV" and "KV-Dash" hoses, in 1/4", 5/16, and 3/8 (3/8 in both standard and dash configuration). Nothing imminent at this time, but updates to follow as we get closer.
Bill Rolik
Re: what paint is used when stamping KV fuel rubber hose?? [Re: bremotorsports] #1721419
01/04/15 08:05 PM
01/04/15 08:05 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
So at least 3 people responded to this post that seem to know but won't say what is used??? I thought we were here to help each other...
Ron
Re: what paint is used when stamping KV fuel rubber hose?? [Re: RJS] #1721420
01/04/15 08:10 PM
01/04/15 08:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm not one of them, I haven't stamped any. I will say this, from the product I've seen so far I wouldn'y use the same ink that the hoses out there now have anyway because it's FAR to easy to wipe off. Something more resilient is needed. There are some special inks out there made for stamping rubber that have a tougher grip and are resistant to some common oil based chemicals and cleaning products, it doesn't appear than anyone making KV hoses are using it. Most of the KV hoses on the market can be wiped clean with dry fingers and a little pressure.
Re: what paint is used when stamping KV fuel rubber hose?? [Re: RJS] #1721421
01/04/15 10:05 PM
01/04/15 10:05 PM
The ink IS the primary focus of my current research, and I am working with an outside company on this. If I am not satisfied with the results, the project will not be advanced. I do not anticipate any further updates for at least 30-45 days, while this issue is being investigated.
Bill Rolik
Re: what paint is used when stamping KV fuel rubber hose?? [Re: bremotorsports] #1721422
01/04/15 11:37 PM
01/04/15 11:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I use silk screeners ink.
I got mine thru a national chain called Sign O Rama
Stamps I had made at a local print shop,,,,,,, other than heater box stamps,,,they came from Rubber Stamp Champ
Re: what paint is used when stamping KV fuel rubber hose?? [Re: gtx6970] #1721423
01/05/15 02:27 AM
01/05/15 02:27 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Original KV stamp was actually quite dull as compared to any of the over bright ones out there today
Re: what paint is used when stamping KV fuel rubber hose?? [Re: mccannix] #1721424
01/05/15 11:31 AM
01/05/15 11:31 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As were most of the other stampings on rubber and hoses of the day (not just white either, yellow, and red were sometimes used in various applications).
Re: what paint is used when stamping KV fuel rubber hose?? [Re: ScottSmith_Harms] #1721425
01/05/15 12:21 PM
01/05/15 12:21 PM
Sweden
Sweden
Good enough for a poor mans resto!
Thanks for all the replies.
Nicklas
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 71redcuda] #1721426
01/05/15 04:30 PM
01/05/15 04:30 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Close-up of an NOS short one
Re: what paint is used when stamping KV fuel rubber hose?? [Re: 71redcuda] #1721427
01/11/15 12:04 PM
01/11/15 12:04 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
I've used commercially avaialable stamping inks that come in squeeze tubes, PK Neuses is one of the companies there is also a company in Texas that sells it but I can't remember the name right now.
As with most things the technique varies the end result very much. What I have found is that in order to not have the hose smudge, thin the ink out with a little bit of acetone on a platen, spread it out with a roller and have it a little tacky before you put your stamp in it. Using this technique the results I have seen is that the stamp ink bleeds into the hose almost and gives an appearance of not much more gloss than the hose itself.
