Re: what paint is used when stamping KV fuel rubber hose??
[Re: ScottSmith_Harms]
#1721415
01/04/15 07:12 PM
01/04/15 07:12 PM
Posts: 1,556 Sweden
71redcuda
Sweden
The hoses are being reproduced, offering such detail might prove counter productive to making future sales.
This hose is not reproduced...
[Re: bremotorsports]
#1721422
01/04/15 11:37 PM
01/04/15 11:37 PM
Posts: 21,762 It's a dry heat
gtx6970
It's a dry heat
I use silk screeners ink. I got mine thru a national chain called Sign O Rama
Stamps I had made at a local print shop,,,,,,, other than heater box stamps,,,they came from Rubber Stamp Champ
#1721425
01/05/15 12:21 PM
01/05/15 12:21 PM
Posts: 1,556 Sweden
71redcuda
Sweden
Good enough for a poor mans resto! Thanks for all the replies. Nicklas
[Re: 71redcuda]
#1721427
01/11/15 12:04 PM
01/11/15 12:04 PM
Posts: 638 SE PA
cudaize
SE PA
Im about to do some stamping on a rubber hose, want the paint to look like the rest of the KV factory hoses.
Anyone know what paint to use?
I've used commercially avaialable stamping inks that come in squeeze tubes, PK Neuses is one of the companies there is also a company in Texas that sells it but I can't remember the name right now.
As with most things the technique varies the end result very much. What I have found is that in order to not have the hose smudge, thin the ink out with a little bit of acetone on a platen, spread it out with a roller and have it a little tacky before you put your stamp in it. Using this technique the results I have seen is that the stamp ink bleeds into the hose almost and gives an appearance of not much more gloss than the hose itself.
