AMD quarters for 69' Coronet, what are the issues? #1717140
12/28/14 08:49 PM
12/28/14 08:49 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
I ordered a quarter for my 69' Bee from Summit. How is the fitment of these? I have read somewhere that the rear window flange is stamped at the wrong angle on the pillar. Any other problems?
Re: AMD quarters for 69' Coronet, what are the issues? [Re: 6PACMAC] #1717141
12/29/14 09:35 PM
12/29/14 09:35 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Some trimming by the roof gutter as they are made to be installed without a roof. Where the quarter meets the bumper requires some attention. But still a nice part in my opinion.
Re: AMD quarters for 69' Coronet, what are the issues? [Re: moparpollack] #1717142
01/03/15 04:04 PM
01/03/15 04:04 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
My quarter is scheduled to arrive Monday, hopefully not bashed up. If all goes well, this will be my spring project.
Re: AMD quarters for 69' Coronet, what are the issues? [Re: 6PACMAC] #1717143
01/03/15 07:41 PM
01/03/15 07:41 PM
South Dakota
hotairballoonpilot Offline
South Dakota
Just installed a pair on a 69 bee post car. No issues as I installed tail panel too. I never trimmed up any of it. I melted the lead out of the sail panel seam. Drilled out the drip rail spot welds by the 1/4 windows slipped it up under the roof and into the area in the drip rail area. Fit it over the factory wheel houses and it was all set. If you have a Facebook account look up Hartford's Best Paint and Body. I should have some pics there.
Corey
Contact Me about AMD Prices
Re: AMD quarters for 69' Coronet, what are the issues? [Re: hotairballoonpilot] #1717144
01/03/15 10:05 PM
01/03/15 10:05 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Corey
. Cool, I will check it out
Re: AMD quarters for 69' Coronet, what are the issues? [Re: 6PACMAC] #1717145
01/05/15 01:24 AM
01/05/15 01:24 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i had problems with the rear window flange angle
and i had to add quite a bit of metal around the wheelwell radius to mate it up to the quarter properly.
Re: AMD quarters for 69' Coronet, what are the issues? [Re: flypaper] #1717146
01/05/15 12:57 PM
01/05/15 12:57 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
. I am going to replace the outer wheel house and the trunk floor extension so maybe I can get those areas to work with out too much grief . The window flange I plan on leaving the original if I have to and cut the replacement panel to fit. We will see how it goes....
Re: AMD quarters for 69' Coronet, what are the issues? [Re: 6PACMAC] #1717147
01/06/15 12:35 AM
01/06/15 12:35 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i replaced both of those parts also.
if i had to do it all over again,i would of spliced what i had to in the wheelwell area instead of replacing the whole thing
because you will be amazed at how bad it will fit all together..
they have retooled that outer wheelwell 3 times that i know of for that very reason.
good luck
Re: AMD quarters for 69' Coronet, what are the issues? [Re: flypaper] #1717148
01/06/15 03:13 PM
01/06/15 03:13 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
good luck
That's how I did a 70 runner I'm working on now and I had to add some metal to on to get it to fit how I liked. The ds fit better than the ps... that's one parts I have yet to get from any manufacturer that fit like an original.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: AMD quarters for 69' Coronet, what are the issues? [Re: Silver70] #1717149
01/06/15 04:12 PM
01/06/15 04:12 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Too bad we're not closer...$200 for both and I cant give this pair of NOS takeoffs away.
Re: AMD quarters for 69' Coronet, what are the issues? [Re: mccannix] #1717150
01/06/15 04:13 PM
01/06/15 04:13 PM
Ontario, Canada
Ontario, Canada
the other side..both crudely cut by someone else below the roofline but solid factory metal.
Re: AMD quarters for 69' Coronet, what are the issues? [Re: mccannix] #1717151
01/06/15 04:14 PM
01/06/15 04:14 PM
Ontario, Canada
Ontario, Canada
insides..
Re: AMD quarters for 69' Coronet, what are the issues? [Re: mccannix] #1717152
01/06/15 04:15 PM
01/06/15 04:15 PM
Ontario, Canada
Ontario, Canada
the other..
Re: AMD quarters for 69' Coronet, what are the issues? [Re: mccannix] #1717153
01/07/15 06:25 PM
01/07/15 06:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ontario, is kinda big , but not that far away , how far from the border ???
Re: AMD quarters for 69' Coronet, what are the issues? [Re: JohnRR] #1717154
01/07/15 06:47 PM
01/07/15 06:47 PM
Ontario, Canada
Ontario, Canada
Jeez John...they were sold to a board member 20 minutes after I posted the pictures...should have said "$200 for both and cant give them away to any cheap Canucks up here".
I'm 10 minutes from the NY state border where they are headed,...
...must be where all the money is.
Re: AMD quarters for 69' Coronet, what are the issues? [Re: mccannix] #1717155
01/07/15 08:05 PM
01/07/15 08:05 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
What happened to the rest of the car? Where do the reflectors go on Canadian quarter panels?
Re: AMD quarters for 69' Coronet, what are the issues? [Re: 69_SIX_PACK] #1717156
01/07/15 08:09 PM
01/07/15 08:09 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
they look cut short in the back?
Re: AMD quarters for 69' Coronet, what are the issues? [Re: flypaper] #1717157
01/07/15 10:33 PM
01/07/15 10:33 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Wow can't believe I / John missed that. Then again I'm a road runner guy
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: AMD quarters for 69' Coronet, what are the issues? [Re: flypaper] #1717158
01/07/15 10:34 PM
01/07/15 10:34 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Ya, those look like about a foot or so are cut off the rear. But they have real nice wheel openings, well worth the price
Re: AMD quarters for 69' Coronet, what are the issues? [Re: 6PACMAC] #1717159
01/07/15 11:05 PM
01/07/15 11:05 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
They sure were
They are going to donate bits and pieces for my Bee. Nice to keep it real with original metal.
