Re: caltrac
[Re: cesar perez]
#1714446
12/23/14 01:57 AM
12/23/14 01:57 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I like sliders, mono leaf and regular caltracs. I also like real good shocks to control them, like a DA afco or Santhuff.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: caltrac
[Re: lockjaw-express]
#1714452
12/23/14 12:57 PM
12/23/14 12:57 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Yes, I talked to John Calvert, and the Mono-leaf would work better, but I will try the SS springs since I do drive the car on the street once in a while.
The rules/inspections are a number issues with Hose clamps, grade 8 bolts and large washers for the battery box, fuel cell, and etc...
I am using SS springs myself with CT this yr for the 1st time.Good luck!
Re: caltrac
[Re: Thumperdart]
#1714454
12/23/14 01:36 PM
12/23/14 01:36 PM
Clanton
northern,Ohio,USA
It`s 2014 people why would we even consider the multi-leaf crap is beyond me but it`s your deal. Caltracs at a minimum w/sliders will go a LONG way when tuned in for your car and I don`t know about you guys but I`m about progress NOT regress..............
If people would be focused on helping people instead of trying to sell them a new car it would be more helpfull.
Re: caltrac
[Re: Clanton]
#1714456
12/23/14 02:03 PM
12/23/14 02:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
People have to learn what the spring does.. what the front and rear of it does.. the front holds the axle in location PLUS gives the lift(pushing down on the axle)... the rear is the spring rate... in racing we just want the rear to hold the body up.. we dont want 14 leafs in the rear... if the rear has multi leafs and is clamped as the body lifts at the hit the pinion is rolling up giving the lift in the front BUT it will also pull the back down.. so you have 2 forces fighting each other.. a single leaf in the rear of the proper rate wont fight as much ![](/ubbthreads/images/graemlins/wave.gif)
Re: caltrac
[Re: Thumperdart]
#1714457
12/23/14 02:31 PM
12/23/14 02:31 PM
Clanton
northern,Ohio,USA
You`re kidding right? Sez the guy w/a blown car on crap springs goin WAY slower than he should........... Too funny.
I do what I can and that is my point about the OP.We can not get there all at once.
Re: caltrac
#1714458
12/23/14 02:43 PM
12/23/14 02:43 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I've been running my split mono's with C-T Bars on the street for a few years now. No issues, don't know why there would be any; in fact, they work great because you can back the preload out of the bars and have a nice soft ride. The bars rely on the controlled flex of the split mono's, and transfer that flex into effective motion. I don't see where adding C-T bars to SS springs (which are just plain stiff) will have any effect. (??) ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: caltrac
[Re: cesar perez]
#1714459
12/23/14 02:44 PM
12/23/14 02:44 PM
MR_P_BODY
The sliders are nice.. just keep them clean.. what MOST people forget is the rubber bushings on old cars are hard and tend to bind up.. if you run shackles the old bushings can cause issues.. they can bind then snap free.. chassis's dont like to be upset.. thats part of the reasons that people really like the sliders.. they put a new item on the car that isnt binding... plus the sliders lower the back of the car and in most cases that helps on traction (gets the CG down a little more so its easier to get the front over the CG point)... but if people would just lube the rubber points now and then it would help ![](/ubbthreads/images/graemlins/wave.gif)
Re: caltrac
[Re: StealthWedge67]
#1714460
12/23/14 03:01 PM
12/23/14 03:01 PM
Clanton
northern,Ohio,USA
I can bend my ss like a twizzler[20* pinion up untell the u jount binds],what would a mono do?By the way Calvert told me if I liked my ride height/spring rate I did not need to go to a mono. ![](/ubbthreads/images/graemlins/popcrn.gif)
Re: caltrac
[Re: Thumperdart]
#1714462
12/23/14 03:11 PM
12/23/14 03:11 PM
Clanton
northern,Ohio,USA
Fightin this all the way.............. Just look at the c-trac design and your q`s will be answered.
I was speaking in relation to spring rate that the ss is more in the front segment]I agree to how the C-T work.
Re: caltrac
[Re: Clanton]
#1714463
12/23/14 03:14 PM
12/23/14 03:14 PM
MR_P_BODY
It sounds like your SS springs are shot...and yes you wouldnt need to change the rear segments if your spring RATE and height are good... they make mono fronts all sorts of thickness BUT I'm sure he told you with the CT bars it would work.. the bars act as a bridge network to stiffen the spring... I assume you know what a bridge network is).. but basically its like a ladder bar but that comes to a single point so it doesnt have anything sliding ![](/ubbthreads/images/graemlins/wave.gif)
