VIN body numbers #1712382
12/18/14 04:34 PM
12/18/14 04:34 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Is it possible that the factory didn't put the vin numbers on the trunk drip rail and radiator support? My 69 bee is in the body shop right now, sanded down (mostly) to bare metal and I'm not finding the vin numbers in those places. Anyone ever had this problem?
2020 RAM Longhorn 4x4
2022 Jeep Grand Cherokee Overland
Re: VIN body numbers [Re: 7812845] #1712383
12/18/14 05:35 PM
12/18/14 05:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Only if was sold as a "body in white" to some racer I'm not sure exactly which year mopar started selling bodys in white for racing Good luck, BTW ,I learned long ago to never say never when it comes to things the car factory did back in the day
Re: VIN body numbers [Re: Cab_Burge] #1712384
12/18/14 09:44 PM
12/18/14 09:44 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
I have seen a few cars missing body #s front and or back but never both.but i haven't seen all cars.what plant?
Re: VIN body numbers [Re: 1970A13] #1712385
12/18/14 09:49 PM
12/18/14 09:49 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a front clip off of a 68 Dart GT that has no numbers on it and it is definitely factory. Though 68's did not have VIN numbers on the body they did have the SO numbers, so they should have been on there. Don't forget, this is Chrysler so anything is possible!
JB Rhinehart, Realist
A-Body's RULE!
Re: VIN body numbers [Re: 1970A13] #1712386
12/18/14 10:18 PM
12/18/14 10:18 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
It is a St. Louis car, and fortunately it does have the fender tag and now that it is in the body shop, mostly sanded down to bare metal, it's plain to see that it is all original, body wise. I did find the part number on the driver's side trunk drip rail, but not a vin number.
Re: VIN body numbers [Re: 7812845] #1712387
12/18/14 10:27 PM
12/18/14 10:27 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Make sure to check both the front and the top of the core support for the number.
Careful, your character's showing!
Re: VIN body numbers [Re: mopar346] #1712388
12/18/14 11:28 PM
12/18/14 11:28 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
This is probably a stupid question, but can you feel where the numbers are stamped, from either side or are they fairly lightly stamped?
Re: VIN body numbers [Re: 7812845] #1712389
12/18/14 11:30 PM
12/18/14 11:30 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If the trunk weatherstrip is in place, you may not see them.
69 B's can be just about anywhere along the trunk lip.
Re: VIN body numbers [Re: RobX4406] #1712390
12/18/14 11:33 PM
12/18/14 11:33 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
I haven't tried on the passenger side yet, and all the trunk seal is mostly gone, but I'll get down to bare metal if necessary.
Re: VIN body numbers [Re: 7812845] #1712391
12/18/14 11:37 PM
12/18/14 11:37 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Its very common for Superbirds to have NO numbers stamped on the radiator core support
Re: VIN body numbers [Re: 7812845] #1712392
12/19/14 12:04 AM
12/19/14 12:04 AM
mopar346 Offline
mopar346  Offline
Some are heavier than others but some can be seen/felt on the backside but many have no signs anything was stamped on the other side.
Re: VIN body numbers [Re: 7812845] #1712393
12/19/14 12:06 AM
12/19/14 12:06 AM
mopar346 Offline
mopar346  Offline
I have personally never seen them any where other than the driver's side seal flange running along the quarter panel. Generally in the middle-ish.
Re: VIN body numbers [Re: mopar346] #1712394
12/19/14 12:34 PM
12/19/14 12:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: VIN body numbers [Re: 7812845] #1712395
12/19/14 12:38 PM
12/19/14 12:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I hope it's not a High dollar car because even with a fender tag and a VIN you still have NOTHING on the Body itself to match it to , the dash and VIN are BOLTED to the body.
Re: VIN body numbers [Re: JohnRR] #1712396
12/19/14 01:24 PM
12/19/14 01:24 PM
Fargo ND
moparphilll Offline
moparphilll  Offline
Fargo ND
I have had Two Cuda's both original paint cars a 1970 and a 1971 both cars missing both #'s.. I was also "freaked out about it to the point I spent $30 for a quick consult with Galan on the subject. He assured me it was possible for the Error to be made on an assembly line of 5 metal cars ( they were stamped before painted)all looking the same rolling done the line, and the Dude that stamps, runs to the bathroom only to return to the wrong place in the line.. "poor Quality control at Chrysler in the 70's Common that could never happen!!!
Re: VIN body numbers [Re: JohnRR] #1712397
12/19/14 06:11 PM
12/19/14 06:11 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Nope, it's not a high dollar car anymore anyway. It's a very late build, spring special car that was an auto on the column, N96 and painted F6. Original engine and trans long gone and converted by previous owner to 4speed, bench seat. I'm putting it back like I want it. 4speed, bucket seats, power steering, and after market tilt steering. I'm retired now and want to make it a little more comfortable.
Re: VIN body numbers [Re: 7812845] #1712398
12/19/14 06:34 PM
12/19/14 06:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If that is the case I would find some stamps and put numbers where they just be JUST IN CASE ....
