Small Block Stroker Question #1711624
12/16/14 09:20 PM
12/16/14 09:20 PM
MN
dustyswinger Offline OP
MN
I don't know if this has been beat to death but I'm putting together another stroker with some parts I have. It will be 550-600 HP. My other stroker had 500 HP and a cast crank and scat H beam rods. My question is what is the best crank and rods to use? It will be a 4 in with a 6.123 rod with .984 pin or at least what I'm planning on. The pistons are flat tops with I think 1.46 compression height, they are weisco forged pistons. I am thinking either Molnar, Bpe or K1. Rods I have looked at are scat, K1 or molnar.
I guess I am looking for input on what you guys like or dislike and have used or want to use. Thanks Craig
Re: Small Block Stroker Question [Re: dustyswinger] #1711625
12/16/14 09:59 PM
12/16/14 09:59 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I have heard so many people beat Eagle parts to death I am a little scared to post my combo. I have a Eagle forged crank and Eagle H beam rods in my 422. I love them. Just took it apart and it had wear but not hurt or beat up. A quick stock rebuild and a little cleaning and it will be good as new. I bet I have 350 or better passes on the engine and a lot of street miles.
6.50 @105.26
Re: Small Block Stroker Question [Re: dustyswinger] #1711626
12/16/14 10:02 PM
12/16/14 10:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
We're it me I would contact Rod Bloomer(BPE) and have him fix you up.
You will get a quality assembly and his knowledge.
Have never heard anything negative about his parts or services.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small Block Stroker Question [Re: B3422W5] #1711627
12/16/14 10:09 PM
12/16/14 10:09 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
BPE is the best to deal with and positively the best value per dollars spent.
Keith
Re: Small Block Stroker Question [Re: Dunnuck Racing] #1711628
12/16/14 10:17 PM
12/16/14 10:17 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would call Rod BPE also. He will get you what you need and give you a smoking deal.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small Block Stroker Question [Re: dustyswinger] #1711629
12/16/14 10:46 PM
12/16/14 10:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Why not eagle ? Alot of my friends use em and to honest you'd be amazed how much powa they throw at it.
Re: Small Block Stroker Question [Re: fishy340] #1711630
12/16/14 11:14 PM
12/16/14 11:14 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I have shopped around a bunch, and Rod at BPE has the best deal, and the best service.
He is a stand up guy, and his parts are very good quality also.
At the very least you owe it to yourself to atleast talk with Rod.
Re: Small Block Stroker Question [Re: fishy340] #1711631
12/17/14 12:09 AM
12/17/14 12:09 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Because he doesn't want sleeves in his block like mine! BOOM!
Re: Small Block Stroker Question [Re: 1967dartgt] #1711632
12/17/14 04:32 AM
12/17/14 04:32 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I currently have a BPE crank, Eagle rods, and Wiseco pistons in mine. You will be hard pressed to find anyone on here that puts more passes on their cars a year than me at my power level. They are out there but point being that the stuff lives.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Small Block Stroker Question [Re: Irun5snd8th] #1711633
12/17/14 06:26 AM
12/17/14 06:26 AM
Earth
Rob C Offline
Rob C  Offline
Earth
How to contact Rod/BPE?
Re: Small Block Stroker Question [Re: 1967dartgt] #1711634
12/17/14 08:56 AM
12/17/14 08:56 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: Small Block Stroker Question [Re: MattW] #1711635
12/17/14 08:57 AM
12/17/14 08:57 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Just need to get him into the G3 stuff also
Re: Small Block Stroker Question *DELETED* [Re: 1967dartgt] #1711636
12/17/14 08:58 AM
12/17/14 08:58 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Post deleted by MattW
Re: Small Block Stroker Question [Re: MattW] #1711637
12/17/14 12:44 PM
12/17/14 12:44 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Got one of Rod's cranks in my 440" stroker, (see attached) makes awesome power rods and mains all blueprinted within spec OOTB and the build was a breeze.
http://youtu.be/JMxHajD_ztw
WIZE
In Car:
Re: Small Block Stroker Question [Re: Streetwize] #1711638
12/17/14 12:57 PM
12/17/14 12:57 PM
Walhalla, SC
BlueDart Offline
BlueDart  Offline
Walhalla, SC
Just last week got complete kit from Rod you can't go wrong dealing with him gonna replace my 3.600 crank that I have ran the past 11 years with a 4.125 kit and see if it picks my Daytona up a little
Re: Small Block Stroker Question [Re: BlueDart] #1711639
12/17/14 01:37 PM
12/17/14 01:37 PM
K
kielbasa Offline
kielbasa  Offline
K
i went thru this a while back also....for the parts you're getting, i don't think you can beat a deal from BPE.....
Re: Small Block Stroker Question [Re: Rob C] #1711640
12/17/14 02:06 PM
12/17/14 02:06 PM
Northern Indiana
Northern Indiana
Easiest way is email
ROD@BLOOMERPERFORMANCE.COM
Keith
Re: Small Block Stroker Question [Re: Dunnuck Racing] #1711641
12/17/14 03:04 PM
12/17/14 03:04 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Thank you thank you!
Re: Small Block Stroker Question [Re: dustyswinger] #1711642
12/17/14 07:59 PM
12/17/14 07:59 PM
SoCal
Brian Hafliger Offline
SoCal
Nothing but great things from both Scat and Molnar!!
Brian Hafliger
Re: Small Block Stroker Question [Re: Brian Hafliger] #1711643
12/27/14 10:07 PM
12/27/14 10:07 PM
BPE Offline
BPE  Offline
Just wanted to thank Craig (dustyswinger) for the crank order.I also wanted to thank all of the members that recommended me and my crankshafts. It means a lot that you guys have my back.
Rod
