Re: 71 cuda - 340 lost, what`s the best replacement?
[Re: Delta]
#1711059
02/28/15 04:11 AM
02/28/15 04:11 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
I'll probably be flogged for this, but 318's are probably more common in Europe, just as they are here on this side of the pond. A cheap (free?) 318 with a stroker crank installed is 390 cubic inches, no slouch & should rev up quickly just like a 340. And it can be dressed like a 340. Given the rarity of the car and it's collector value, you should long term look at finding a correct '71 340.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Delta]
#1711060
03/13/15 09:44 PM
03/13/15 09:44 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I don't get all the " the 340 is much more expensive, so build a 360 statements". Fact is, if you look around at all, 340 blocks are easy to find and rarely more than 600-800 dollars. Even if you find a suitable 360 block for 100 dollars, in the whole scheme of the whole motor build you have maybe 500-700 dollars more money in the 340 build( cost difference of the block) Many times you can find a 340 short block with steel crank for not much if any more than the price I stated above for just the block.... Needing rebuilt. You pick up the quality steel crank that can take a lot of punishment and is a nice piece. For a car like yours, for very little difference in money I would i put another 340 in it( or a stroked 340)/416.... No brainer Edit.... Didn't notice I hadreplied to this thread months ago.... Lol
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: GO_Fish]
#1711061
03/16/15 04:00 PM
03/16/15 04:00 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
... A cheap (free?) 318 with a stroker crank installed is 390 cubic inches, no slouch & should rev up quickly just like a 340...
Not argumentative, but I've heard there was a problem with valve shrouding when you when with larger valves. Something about notching the cylinder wall tops. Can a 318 breath well enough to make power with a stroker crank?
[Re: Delta]
#1711064
03/29/15 01:09 AM
03/29/15 01:09 AM
GO_Fish
Maryland
I think the carb and intake manifold are different between '70-71. '70 still used the square bore AVS, and '71 was the first year spread bore Thermoquad? And I think the '71 was a one year carb before an improved version came in '72? Someone check me on this, ScottSmith Harms?
Scott B.
