Page 4 of 4 1 2 3 4
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: dogdays] #1711058
02/25/15 06:31 PM
02/25/15 06:31 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
got it, thanks.
In the for sale section you just "reply" to the last post. Put your own title in it, though.
R.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711059
02/28/15 04:11 AM
02/28/15 04:11 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'll probably be flogged for this, but 318's are probably more common in Europe, just as they are here on this side of the pond. A cheap (free?) 318 with a stroker crank installed is 390 cubic inches, no slouch & should rev up quickly just like a 340. And it can be dressed like a 340. Given the rarity of the car and it's collector value, you should long term look at finding a correct '71 340.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711060
03/13/15 09:44 PM
03/13/15 09:44 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I don't get all the " the 340 is much more expensive, so build a 360 statements".
Fact is, if you look around at all, 340 blocks are easy to find and rarely more than 600-800 dollars.
Even if you find a suitable 360 block for 100 dollars, in the whole scheme of the whole motor build you have maybe 500-700 dollars more money in the 340 build( cost difference of the block)
Many times you can find a 340 short block with steel crank for not much if any more than the price I stated above for just the block.... Needing rebuilt. You pick up the quality steel crank that can take a lot of punishment and is a nice piece.
For a car like yours, for very little difference in money I would i put another 340 in it( or a stroked 340)/416.... No brainer
Edit.... Didn't notice I hadreplied to this thread months ago.... Lol
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: GO_Fish] #1711061
03/16/15 04:00 PM
03/16/15 04:00 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
... A cheap (free?) 318 with a stroker crank installed is 390 cubic inches, no slouch & should rev up quickly just like a 340...
Not argumentative, but I've heard there was a problem with valve shrouding when you when with larger valves. Something about notching the cylinder wall tops. Can a 318 breath well enough to make power with a stroker crank?
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Vert] #1711062
03/21/15 12:48 AM
03/21/15 12:48 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I guess we'd have to ask someone who has one? Sounds like it could be a problem with 2.02 intake valves or larger... If I were building a 390 I'd put a set of Mag heads (1.92 intake??) & port them. They'd flow fine for 390 c.i. You can bolt LA covers on Mag heads, to dress it as a 340. Only hardcore Moparts guys would likely sniff out something unusual (no X or J or heat crossover. Pic of my LA 360 with Mag heads dressed as a 68 340.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: GO_Fish] #1711063
03/28/15 11:14 PM
03/28/15 11:14 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
I decided to go original, that means to find correct 340. There is one 340 availabale currently close to me, it is produced in september 71 (blue painted). Was this engine used for 71 model year, or only in 72 models? Any major difference in comparison to 70-71 engine?
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711064
03/29/15 01:09 AM
03/29/15 01:09 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I think the carb and intake manifold are different between '70-71. '70 still used the square bore AVS, and '71 was the first year spread bore Thermoquad? And I think the '71 was a one year carb before an improved version came in '72? Someone check me on this, ScottSmith Harms?
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: GO_Fish] #1711065
03/29/15 03:49 AM
03/29/15 03:49 AM
north carolina
d100dragracer Offline
north carolina
The 2.02 valves being a problem like requiring bore notching and such on a 318 is something that was started many many years ago and simply is not true. As I have run 2.02 valves many times in several different 318's with no issues. Think about it all 318 340 360 LA heads have the exact same valve spacing add 2.02 intake size and 1.60 exhaust size together that is 3.620 and a 318 stock bore size is 3.910 there is no where near .290 separation between the intake and exhaust valves on any of these heads it would probably be a issue using 2.02 valves on a 273 but it never has been on a 318 and I don't see valve shrouding being a issue neither all the 2.02 valve heads I have put on a 318 have always made a major difference in power as long as you deck the head or block to keep the compression from dropping I have used new pistons many times though with valve reliefs in them because you cant run much cam with 318 stock flat tops with no valve reliefs cut in them. My
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711066
03/29/15 10:20 AM
03/29/15 10:20 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The last month of 1971 production was July 1971 so your September engine find would have been from a 1972 model year car. There were small differences between 71 & 72 340's but nothing huge or difficult to change to 71 specs when you rebuild it.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: ScottSmith_Harms] #1939098
10/26/15 07:16 PM
10/26/15 07:16 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
...it`s been some time since my last post. Finally I got date correct 340 from local member. Now I can move to another missing part - clutch and flywheel. Could you guys help me, what flywheel should I use? I found they sell 130 and 143 tooth, which one is correct? Would you recommend steel or aluminium (they are almost the same price). How about cluth set? They sell many different kind from $100 to $1000, any recommendation on a good one? I will keep the engine mostly stock, maybe few upgrades, but not over 400 HP.
340 is internally balanced?
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1939371
10/27/15 12:17 AM
10/27/15 12:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
For the street I recommend a steel flywheel, 10.50" 130 tooth which will fit into the stock bell housing, a 143 is an 11.00" and won't fit.
Call Wayne Brewer or Jamie Passon for a clutch, I recommend a stock style McCleod (roughly $600-$700.00 a set).
All 1968 through early 1972 340's were originally equipped with a forged steel crank and are internally balanced, later date 340's equipped with a cast crank were externally balanced.
Page 4 of 4 1 2 3 4
