Melting engine compartment harness clip – Max Wedge #1707812
12/07/14 05:47 PM
12/07/14 05:47 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
My friend has a 1963 Plymouth Fury - Max Wedge with exhaust manifolds. Earlier this week, he replaced the white clip that retains the engine compartment wire harness. This clip is the closest point to the exhaust manifold. Yesterday, he had to replace the new clip because it melted. He just purchased (10) of the white clips from Bill & Rose Evans this week. Anyone else experience this melting issue?
Re: Melting engine compartment harness clip – Max Wedge [Re: vinnyd76] #1707813
12/07/14 07:59 PM
12/07/14 07:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
No but his exhaust temps may be running high for a variety of reasons
Re: Melting engine compartment harness clip – Max Wedge [Re: TJP] #1707814
12/07/14 08:21 PM
12/07/14 08:21 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I have not. I'd suggest checking with evans to let them know. possible it's not made of heat resistant material.
other post may be considered as well, yet if it's not hot...
I just re-read op, was the original clip from evans? If not, might not have the problem after.
Re: Melting engine compartment harness clip – Max Wedge [Re: vinnyd76] #1707815
12/07/14 08:27 PM
12/07/14 08:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Got a IR temp heat gun? How hot is it as soon as he opens the hood after a long drive?
I bet the motor is lean which makes them run hot, my guess.
If it's that clip in the picture, then yes that motor is lean!! because the clip is pretty far away IMO.
Re: Melting engine compartment harness clip – Max Wedge [Re: Challenger 1] #1707816
12/07/14 09:35 PM
12/07/14 09:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
These have been on for three years,O.E.M.,discolored a little but not much.
Re: Melting engine compartment harness clip – Max Wedge [Re: 62maxwgn] #1707817
12/07/14 11:08 PM
12/07/14 11:08 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
those repop clips melt, factory clips withstand the temps.
Re: Melting engine compartment harness clip – Max Wedge [Re: MO_PA] #1707818
12/08/14 12:01 AM
12/08/14 12:01 AM
minnesota
dk426 Offline
dk426  Offline
minnesota
max wedge car did not use plastic they had metal clips
Re: Melting engine compartment harness clip – Max Wedge [Re: dk426] #1707819
12/08/14 12:28 AM
12/08/14 12:28 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Makes you think they might of had a reason for that.
Don't be the exception.
Re: Melting engine compartment harness clip – Max Wedge [Re: Supercuda] #1707820
12/08/14 06:49 PM
12/08/14 06:49 PM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
Absolutely... reproductions available from Crossram Connection... 3 for the driver side and 2 for the passanger side.
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Melting engine compartment harness clip – Max Wedge [Re: Anselmi] #1707821
12/08/14 09:03 PM
12/08/14 09:03 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And a 2 additional metal clips on the firewall{brake line and wiring harness}...
