what will it run
#170663
12/19/08 12:51 PM
12/19/08 12:51 PM
finally building the stroker this winter it will be 435 with 13.5to 1 comp. gas ported pistons roller cam around 274/277 duration Indy intake 1050 dominator 8in. 5100 conv. 457 gear 30x11.5 slick ladder bar 2985lb. the car with a 11 to 1 .030 over 340 ran a best 10.6 what is your guess on et., 60ft, mph.
Re: what will it run
[Re: MR_P_BODY]
#170665
12/19/08 01:04 PM
12/19/08 01:04 PM
thanks for the reply Mr. P I am hoping for a little better than that but I may be unrealistic
[Re: Thumperdart]
#170668
12/19/08 01:16 PM
12/19/08 01:16 PM
I forgot they are ported W2s thanks for the replies
#170669
12/19/08 01:32 PM
12/19/08 01:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you know the numbers?
[Re: MR_P_BODY]
#170670
12/19/08 01:36 PM
12/19/08 01:36 PM
no I do not know any flow no. Mr. P thanks
#170671
12/19/08 02:54 PM
12/19/08 02:54 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
If the heads are good, at that weight probably low 9.70's at 136 ish
#170674
12/19/08 08:13 PM
12/19/08 08:13 PM
Posts: 1,073 oregon
greendart408
oregon
I had almost exact combo but my car weighed 3050 and only 408cu, mine went 9.83@134.90 with only 40 passes on that combo before I tore it down to change my combo. There was more left in it im sure.
[Re: greendart408]
#170675
12/19/08 10:38 PM
12/19/08 10:38 PM
thanks for the replies did you receive a cam to regrind yet Ryan talk to you later
