what will it run
#170663
12/19/08 12:51 PM
12/19/08 12:51 PM
finally building the stroker this winter it will be 435 with 13.5to 1 comp. gas ported pistons roller cam around 274/277 duration Indy intake 1050 dominator 8in. 5100 conv. 457 gear 30x11.5 slick ladder bar 2985lb. the car with a 11 to 1 .030 over 340 ran a best 10.6 what is your guess on et., 60ft, mph.
Re: what will it run
[Re: MR_P_BODY]
#170665
12/19/08 01:04 PM
12/19/08 01:04 PM
thanks for the reply Mr. P I am hoping for a little better than that but I may be unrealistic
[Re: Thumperdart]
#170668
12/19/08 01:16 PM
12/19/08 01:16 PM
I forgot they are ported W2s thanks for the replies
#170669
12/19/08 01:32 PM
12/19/08 01:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you know the numbers?
[Re: MR_P_BODY]
#170670
12/19/08 01:36 PM
12/19/08 01:36 PM
no I do not know any flow no. Mr. P thanks
#170671
12/19/08 02:54 PM
12/19/08 02:54 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
If the heads are good, at that weight probably low 9.70's at 136 ish
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
#170674
12/19/08 08:13 PM
12/19/08 08:13 PM
Posts: 1,072 oregon
greendart408
oregon
I had almost exact combo but my car weighed 3050 and only 408cu, mine went 9.83@134.90 with only 40 passes on that combo before I tore it down to change my combo. There was more left in it im sure.
[Re: greendart408]
#170675
12/19/08 10:38 PM
12/19/08 10:38 PM
thanks for the replies did you receive a cam to regrind yet Ryan talk to you later
