what will it run #170663
12/19/08 12:51 PM
12/19/08 12:51 PM
Anonymous OP
Anonymous OP
finally building the stroker this winter it will be 435 with 13.5to 1 comp. gas ported pistons roller cam around 274/277 duration Indy intake 1050 dominator 8in. 5100 conv. 457 gear 30x11.5 slick ladder bar 2985lb. the car with a 11 to 1 .030 over 340 ran a best 10.6 what is your guess on et., 60ft, mph.
Re: what will it run #170664
12/19/08 01:01 PM
12/19/08 01:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinking a 9.95 at 134 if you can hook up with
a 1.30 60'
Re: what will it run [Re: MR_P_BODY] #170665
12/19/08 01:04 PM
12/19/08 01:04 PM
Anonymous OP
Anonymous OP
thanks for the reply Mr. P I am hoping for a little better than that but I may be unrealistic
Re: what will it run #170666
12/19/08 01:06 PM
12/19/08 01:06 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Assuming w2's by your sig' name?
Depends how good the heads are...
Re: what will it run #170667
12/19/08 01:10 PM
12/19/08 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Probably faster than me.....
Re: what will it run [Re: Thumperdart] #170668
12/19/08 01:16 PM
12/19/08 01:16 PM
Anonymous OP
Anonymous OP
I forgot they are ported W2s thanks for the replies
Re: what will it run #170669
12/19/08 01:32 PM
12/19/08 01:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you know the numbers?
Re: what will it run [Re: MR_P_BODY] #170670
12/19/08 01:36 PM
12/19/08 01:36 PM
Anonymous OP
Anonymous OP
no I do not know any flow no. Mr. P thanks
Re: what will it run #170671
12/19/08 02:54 PM
12/19/08 02:54 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
If the heads are good, at that weight probably low 9.70's at 136 ish
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: what will it run [Re: B3422W5] #170672
12/19/08 03:09 PM
12/19/08 03:09 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: what will it run #170673
12/19/08 03:58 PM
12/19/08 03:58 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Hmm this combo sounds awfully familiar......
The quality of the heads will dictate the ET.....
Re: what will it run #170674
12/19/08 08:13 PM
12/19/08 08:13 PM
oregon
greendart408 Offline
oregon
I had almost exact combo but my car weighed 3050 and only 408cu, mine went 9.83@134.90 with only 40 passes on that combo before I tore it down to change my combo. There was more left in it im sure.
Re: what will it run [Re: greendart408] #170675
12/19/08 10:38 PM
12/19/08 10:38 PM
Anonymous OP
Anonymous OP
thanks for the replies did you receive a cam to regrind yet Ryan talk to you later
