8 3/4 Back brace question
#170626
12/19/08 12:28 PM
12/19/08 12:28 PM
Posts: 326 Davenport, IA
70shaker
Davenport, IA
When adding a back brace do you guys completely weld or skip weld it. Also do you weld the ends of the brace to the axle tubes?
Ex Hemi Racer 70 Challenger Hemi 4 speed clone
Re: 8 3/4 Back brace question
[Re: 70shaker]
#170627
12/19/08 01:06 PM
12/19/08 01:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I welded the whole thing but I dont think you need too. On the ends I left enough material that I could fold it down on top of the bearing flange. I used 2X3 tubing EDIT Here is a pic
[Re: MR_P_BODY]
#170628
12/19/08 04:18 PM
12/19/08 04:18 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I am going to be ordering a brace soon myself, finally. I plan on sticth welding it all the way around but will be continuous when I'm done. Like doing a body panel..Who has the best fitting one? Mancini?
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: 70shaker]
#170629
12/19/08 04:36 PM
12/19/08 04:36 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
Mine is continuously welded as well, it's made from 2x4 tube.
CrAzYMoPaRGuY
[Re: KatFysh]
#170630
12/19/08 04:50 PM
12/19/08 04:50 PM
MR_P_BODY
I dont know who offers the best, I made mine out of the 2X3, but if yours is a longer housing then you might be better off using the 2X4 stock like Crazy did, it leaves you enough material at the ends for a wall
[Re: Mr.Yuck]
#170632
12/19/08 05:13 PM
12/19/08 05:13 PM
MR_P_BODY
I was told to not run a continuous bead as it could warp the tube and...weld it with the axles in.
If you stitch weld it(jumping all around) with 1" beads and cool it, its not a problem but after doing a few I really dont think its necessary for a full weld JMO
[Re: moparniac]
#170637
12/19/08 06:50 PM
12/19/08 06:50 PM
MR_P_BODY
For a little more work I think its worth the time and effort to go out to and on to the bearing flange with the brace. I have seen where they bend at the outter edge of the spring mount. All you have to do is notch around the edge of the spring mount wall and drill the holes through the brace but it picks up alot of strength out at the ends.... JMO
[Re: CrAzYMoPaRGuY]
#170641
12/19/08 10:38 PM
12/19/08 10:38 PM
MR_P_BODY
the best thing I did to give my 8 3/4 life was sell the 8 3/4 and had a dana 60 built
Thanks for that useful piece of information!
LOL, thought Tony changed his name
[Re: CrAzYMoPaRGuY]
#170643
12/19/08 11:35 PM
12/19/08 11:35 PM
MR_P_BODY
I tied mine into the bearing flange, but just the edge. The diff that came out of the car wasn't quite as short, it wasn't backbraced, and it was easily identifiable as "BOW" shaped. Even from a distance... This is the new diff, I'm wondering if I should have brought the backbrace out even further? I dont know, it looks fairly short(the housing width) so it would deflex less. I went out on to the flange just short of the wall so I could weld there
[Re: MR_P_BODY]
#170644
12/20/08 02:49 PM
12/20/08 02:49 PM
70shaker
Davenport, IA
Thanks for the input guys
