8 3/4 Back brace question #170626
12/19/08 12:28 PM
12/19/08 12:28 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
When adding a back brace do you guys completely weld or skip weld it. Also do you weld the ends of the brace to the axle tubes?
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: 8 3/4 Back brace question [Re: 70shaker] #170627
12/19/08 01:06 PM
12/19/08 01:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I welded the whole thing but I dont think you need
too. On the ends I left enough material that I could
fold it down on top of the bearing flange. I used
2X3 tubing
EDIT
Here is a pic
Re: 8 3/4 Back brace question [Re: MR_P_BODY] #170628
12/19/08 04:18 PM
12/19/08 04:18 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I am going to be ordering a brace soon myself, finally. I plan on sticth welding it all the way around but will be continuous when I'm done. Like doing a body panel..Who has the best fitting one? Mancini?
When you decide to quit, THAT is the moment when you would've succeeded..
Re: 8 3/4 Back brace question [Re: 70shaker] #170629
12/19/08 04:36 PM
12/19/08 04:36 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Mine is continuously welded as well, it's made from 2x4 tube.
CrAzYMoPaRGuY
Re: 8 3/4 Back brace question [Re: KatFysh] #170630
12/19/08 04:50 PM
12/19/08 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know who offers the best, I made mine out
of the 2X3, but if yours is a longer housing then
you might be better off using the 2X4 stock like Crazy did,
it leaves you enough material at the ends for a wall
Re: 8 3/4 Back brace question [Re: 70shaker] #170631
12/19/08 05:04 PM
12/19/08 05:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I was told to not run a continuous bead as it could warp the tube and...weld it with the axles in.
Re: 8 3/4 Back brace question [Re: Mr.Yuck] #170632
12/19/08 05:13 PM
12/19/08 05:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you stitch weld it(jumping all around) with 1" beads
and cool it, its not a problem but after doing a
few I really dont think its necessary for a full
weld JMO
Re: 8 3/4 Back brace question [Re: MR_P_BODY] #170633
12/19/08 05:47 PM
12/19/08 05:47 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
mine was skip welded
Mopar Performance
Re: 8 3/4 Back brace question [Re: MR_P_BODY] #170634
12/19/08 05:50 PM
12/19/08 05:50 PM
Canada
Canada
I only started with 2x4 stock because I wanted a rear flat section for my load bolt provisions.
CrAzYMoPaRGuY
Re: 8 3/4 Back brace question [Re: CrAzYMoPaRGuY] #170635
12/19/08 05:54 PM
12/19/08 05:54 PM
GoDartGo Offline
GoDartGo  Offline
ugly, but it's what I had.
Re: 8 3/4 Back brace question [Re: GoDartGo] #170636
12/19/08 06:08 PM
12/19/08 06:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: 8 3/4 Back brace question [Re: moparniac] #170637
12/19/08 06:50 PM
12/19/08 06:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For a little more work I think its worth the time
and effort to go out to and on to the bearing flange
with the brace. I have seen where they bend at the
outter edge of the spring mount. All you have to do
is notch around the edge of the spring mount wall
and drill the holes through the brace but it picks
up alot of strength out at the ends.... JMO
Re: 8 3/4 Back brace question [Re: MR_P_BODY] #170638
12/19/08 08:49 PM
12/19/08 08:49 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
the best thing I did to give my 8 3/4 life was sell the 8 3/4 and had a dana 60 built
Mopar Performance
Re: 8 3/4 Back brace question [Re: moparniac] #170639
12/19/08 09:29 PM
12/19/08 09:29 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
On the 64 Plymouth we bolted the rear at the pumpkin to a long piece of "C" channel and shimed and clamped the housing ends to the channel, then skip welded the back brace. Nothing moved when we unclamped everything.
Re: 8 3/4 Back brace question [Re: moparniac] #170640
12/19/08 10:26 PM
12/19/08 10:26 PM
Canada
Canada
Thanks for that useful piece of information!
CrAzYMoPaRGuY
Re: 8 3/4 Back brace question [Re: CrAzYMoPaRGuY] #170641
12/19/08 10:38 PM
12/19/08 10:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL, thought Tony changed his name
Re: 8 3/4 Back brace question [Re: MR_P_BODY] #170642
12/19/08 11:15 PM
12/19/08 11:15 PM
Canada
Canada
I tied mine into the bearing flange, but just the edge.
The diff that came out of the car wasn't quite as short, it wasn't backbraced, and it was easily identifiable as "BOW" shaped. Even from a distance...
This is the new diff, I'm wondering if I should have brought the backbrace out even further?
CrAzYMoPaRGuY
Re: 8 3/4 Back brace question [Re: CrAzYMoPaRGuY] #170643
12/19/08 11:35 PM
12/19/08 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know, it looks fairly short(the housing width)
so it would deflex less. I went out on to the flange
just short of the wall so I could weld there
Re: 8 3/4 Back brace question [Re: MR_P_BODY] #170644
12/20/08 02:49 PM
12/20/08 02:49 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
Thanks for the input guys
Ex Hemi Racer
