555 to 572 C.I. vacume pumps, who's good? #1705962
12/02/14 05:07 PM
12/02/14 05:07 PM
Cab_Burge Offline OP
I'm working up a quote for a customer who wants a B1 motor, 555 to 572 C.I. range and he wants it to make as much power as he can at or under 7500 RPM N/A. I've never used a vacume pump on any motor yet but I want to on this motor, which pump do you use and which ones, Moroso, Star and any others, are the best to use in this deal All comments and help appreciated
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: Cab_Burge] #1705963
12/02/14 05:19 PM
12/02/14 05:19 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
4 vane moroso is a good choice
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: WHITEDART] #1705964
12/02/14 05:33 PM
12/02/14 05:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Star makes the best stuff. Having said that we have had really good luck with Moroso stuff.
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: Cab_Burge] #1705965
12/02/14 05:37 PM
12/02/14 05:37 PM
an8sec70cuda Offline
Star, Moroso, and GZ are all good. I have an Aerospace pump and do not care for it. We have a Moroso pump on the Camaro and it works good. Star is kinda expensive. Have heard good things about the GZ pumps...will be putting one on my hemi when my Aerospace pump craps out again.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: an8sec70cuda] #1705966
12/02/14 07:31 PM
12/02/14 07:31 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If he really wants max performance ask him if he would like to use a dry sump and have the pump designed to pull the vacuum.
2011 Drag Pak Challenger
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: Cab_Burge] #1705967
12/02/14 07:45 PM
12/02/14 07:45 PM
AndyF Offline
AndyF  Offline
Cab, I have a Moroso 4 vane enhanced pump that only has a few dyno pulls on it. Shoot me a note if you're interested. I can save you some money on the complete setup with pulley and bracket. I also have the Moroso drive mandrel kit too. I switched to a dry sump so I don't need these parts anymore.
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: AndyF] #1705968
12/02/14 08:52 PM
12/02/14 08:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Do some research and you'll find that the GZ Motorsports stuff is very nice for about the same $ as Moroso.
http://www.gzmotorsports.com/
Doug
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: AndyF] #1705969
12/02/14 09:15 PM
12/02/14 09:15 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I like the GZ stuff
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: camastomcat] #1705970
12/04/14 12:15 AM
12/04/14 12:15 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I use a Star pump and catch can. Never had the need to drain oil out of the unit. I clean it once a season. Great product.
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: sjs64polara] #1705971
12/04/14 02:22 AM
12/04/14 02:22 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We used Aerospace until we tried Star Machine. No contest.
Star.
Todd
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: sasquatch] #1705972
12/04/14 02:29 AM
12/04/14 02:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Star.
Todd
I never liked the Aerospace after I put it on...
of all the units out there Aerospace is dead last..
I flowed air pumps at work that were better.. by a
good bit
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: Cab_Burge] #1705973
12/04/14 08:15 AM
12/04/14 08:15 AM
gregsdart Offline
gregsdart  Offline
Running a 528 wedge, I tried a GPZ years ago, couldn't pull enough to show 3 inch vacuum. Went to a Moroso three vane, got max 10 inch running 50 percent engine speed. I suspect the four vane enhanced Moroso would be ideal, as you can regulate it down and run it fairly slow to get the same results, improving pump life.
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: gregsdart] #1705974
12/04/14 09:21 AM
12/04/14 09:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My GPZ will pull 7-8 at idle.
Doug
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: dvw] #1705975
12/04/14 03:33 PM
12/04/14 03:33 PM
gregsdart Offline
gregsdart  Offline
Doug
The year was 2003, and the pump was a converted Pinto smog pump. I believe they were GZ then? I called them three times and they never responded. So they have one dissatisfied customer. Glad your pump works. They may have totally changed their product since, but you know how it is. Burn me once,,,,,,,,,,,
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: dvw] #1705976
12/04/14 07:39 PM
12/04/14 07:39 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Doug
You might want to be more interested in what it is pulling at the 1/8 or 1/4 mile which ever you run in other words wide open throttle that counts.That is not a smart remark just saying to much vacuum can do more damage than good on a wet sump engine. I don't know how to spell the fancy word for it,but when you have to much vacuum it dead locks your oil pump.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: MRMOPAR622] #1705977
12/04/14 10:27 PM
12/04/14 10:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
I haven't run over 12", yet. It has and adjuster to allow it to draw outside air to reduce vacuum. I have it open nearly all the way. Check out their website and compare CFM to other brands.
Doug
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: dvw] #1705978
12/05/14 12:31 AM
12/05/14 12:31 AM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
star is the best you can get. with their tank the pump never sees oil or fragments if there is a failure.
Re: 555 to 572 C.I. vacume pumps, who's good? [Re: Cab_Burge] #1705979
12/05/14 10:34 AM
12/05/14 10:34 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
With out a doubt Star pumps
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
