555 to 572 C.I. vacume pumps, who's good?
#1705962
12/02/14 05:07 PM
12/02/14 05:07 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
I'm working up a quote for a customer who wants a B1 motor, 555 to 572 C.I. range and he wants it to make as much power as he can at or under 7500 RPM N/A. I've never used a vacume pump on any motor yet but I want to on this motor, which pump do you use and which ones, Moroso, Star and any others, are the best to use in this deal All comments and help appreciated
Re: 555 to 572 C.I. vacume pumps, who's good?
[Re: Cab_Burge]
#1705963
12/02/14 05:19 PM
12/02/14 05:19 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
4 vane moroso is a good choice
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1705964
12/02/14 05:33 PM
12/02/14 05:33 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Star makes the best stuff. Having said that we have had really good luck with Moroso stuff.
[Re: Cab_Burge]
#1705965
12/02/14 05:37 PM
12/02/14 05:37 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Star, Moroso, and GZ are all good. I have an Aerospace pump and do not care for it. We have a Moroso pump on the Camaro and it works good. Star is kinda expensive. Have heard good things about the GZ pumps...will be putting one on my hemi when my Aerospace pump craps out again.
[Re: an8sec70cuda]
#1705966
12/02/14 07:31 PM
12/02/14 07:31 PM
Posts: 2,661 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
If he really wants max performance ask him if he would like to use a dry sump and have the pump designed to pull the vacuum.
2011 Drag Pak Challenger
[Re: AndyF]
#1705968
12/02/14 08:52 PM
12/02/14 08:52 PM
Posts: 9,861 MI, usa
dvw
MI, usa
Do some research and you'll find that the GZ Motorsports stuff is very nice for about the same $ as Moroso. http://www.gzmotorsports.com/Doug
[Re: sasquatch]
#1705972
12/04/14 02:29 AM
12/04/14 02:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
We used Aerospace until we tried Star Machine. No contest. Star. Todd
I never liked the Aerospace after I put it on... of all the units out there Aerospace is dead last.. I flowed air pumps at work that were better.. by a good bit
[Re: Cab_Burge]
#1705973
12/04/14 08:15 AM
12/04/14 08:15 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Running a 528 wedge, I tried a GPZ years ago, couldn't pull enough to show 3 inch vacuum. Went to a Moroso three vane, got max 10 inch running 50 percent engine speed. I suspect the four vane enhanced Moroso would be ideal, as you can regulate it down and run it fairly slow to get the same results, improving pump life.
[Re: gregsdart]
#1705974
12/04/14 09:21 AM
12/04/14 09:21 AM
dvw
MI, usa
My GPZ will pull 7-8 at idle. Doug
[Re: dvw]
#1705975
12/04/14 03:33 PM
12/04/14 03:33 PM
gregsdart
The year was 2003, and the pump was a converted Pinto smog pump. I believe they were GZ then? I called them three times and they never responded. So they have one dissatisfied customer. Glad your pump works. They may have totally changed their product since, but you know how it is. Burn me once,,,,,,,,,,,
[Re: MRMOPAR622]
#1705977
12/04/14 10:27 PM
12/04/14 10:27 PM
dvw
MI, usa
You might want to be more interested in what it is pulling at the 1/8 or 1/4 mile which ever you run in other words wide open throttle that counts.That is not a smart remark just saying to much vacuum can do more damage than good on a wet sump engine. I don't know how to spell the fancy word for it,but when you have to much vacuum it dead locks your oil pump.
I haven't run over 12", yet. It has and adjuster to allow it to draw outside air to reduce vacuum. I have it open nearly all the way. Check out their website and compare CFM to other brands. Doug
[Re: Cab_Burge]
#1705979
12/05/14 10:34 AM
12/05/14 10:34 AM
Posts: 503 Idaho
1320Dart
Idaho
With out a doubt Star pumps
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
