70 challenger RT #1705429
12/01/14 12:42 PM
12/01/14 12:42 PM
Nebraska, USA
David68charger Offline OP
Nebraska, USA
Ok
I have a question for my 70 challenger RT.
I would like to put a set of Rallye wheels on my car.
So, can I put 15x8 wheels and BFG 275/60/15 on rear and 15x7 235/60/15 on front? If so, will the trim rings fit the 8 inch rim on the back?
Is this the factory specs?
Thanks for your help.
David
Re: 70 challenger RT [Re: David68charger] #1705430
12/01/14 03:20 PM
12/01/14 03:20 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
A factory 15x7 trim ring obviously won't fill the complete outboard side of the rim unless the back-spacing is where the additional 1" is. You might find a trim ring for a 15x8 application (like a Corvette trim ring)?
Troy
Houston Mopar Connection Club
Re: 70 challenger RT [Re: David68charger] #1705431
12/01/14 03:34 PM
12/01/14 03:34 PM
central il.
second 70 Offline
second 70  Offline
central il.
Dave the 275 nitto's on 15 x8 rims rubbed on my 70 cuda. The trim rings don't fit well and would spin on my rims.
You can get by using the 275's on a 7" rim and they will fit. I would use 225/70/15 on the front on 7" rims. They are taller and the car sets much nicer. Mike
Re: 70 challenger RT [Re: hemi68charger] #1705432
12/01/14 04:08 PM
12/01/14 04:08 PM
Nebraska, USA
Nebraska, USA
Ok thank you.
David
Re: 70 challenger RT [Re: second 70] #1705433
12/01/14 04:11 PM
12/01/14 04:11 PM
Nebraska, USA
Nebraska, USA
Oh ok. The 275's rubbed? Hmm.So the 15inch wheel must have been factory for the front and the back.
Re: 70 challenger RT [Re: second 70] #1705434
12/01/14 04:13 PM
12/01/14 04:13 PM
Nebraska, USA
Nebraska, USA
It seems weird that they would make the 8 inch wheel but not a trim ring that fits correctly.
Re: 70 challenger RT [Re: David68charger] #1705435
12/01/14 04:26 PM
12/01/14 04:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If they would have made a 8" rally wheel which they did not,they would have a ring to go with it !!
Re: 70 challenger RT [Re: 62maxwgn] #1705436
12/01/14 07:47 PM
12/01/14 07:47 PM
france
jose jones Offline
jose jones  Offline
france
The trim rings are made for a 7 inch wheel, If you want to run 8 inch wheels, check the backspacing and add the extra inch to the backside, a 275-60-15 fits better on a 8 inch rim if possible
Re: 70 challenger RT [Re: jose jones] #1705437
12/01/14 09:33 PM
12/01/14 09:33 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
On your tire sizes 235 60-15 works but a 245 60-15 looks nicer and is more in line with a F-60 15 PolyGlas in size.
The 275 60-15 is no problem either. This is a picture of my old Cuda
235 60-15 and 275 60-15 on 7" steel wheels front and back.
Ron
Re: 70 challenger RT [Re: RJS] #1705438
12/01/14 09:36 PM
12/01/14 09:36 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Same car with 7" front and 8" rear
F 60-15 and L 60-15 PolyGlas.
This also answers your trim ring question.
Ron
Re: 70 challenger RT [Re: RJS] #1705439
12/01/14 09:38 PM
12/01/14 09:38 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Even though Corvettes used 15x8 rims the trim rings were no deeper than ours and left a gap.
Ron
Re: 70 challenger RT [Re: RJS] #1705440
12/01/14 10:21 PM
12/01/14 10:21 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
I have 245/60 15's on 7 inch wide ralleys on all 4 corners on my 70 challenger. Tires do not rub.
Jess
Yeah, it's hopped up to over 160...
Re: 70 challenger RT [Re: jt4406] #1705441
12/02/14 12:44 PM
12/02/14 12:44 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
My Challenger has 275's on rear with the 15x7 rallyes, and 245's on the front. 15x8's would likely rub.
1971 BS23H1B
Re: 70 challenger RT [Re: tx9cuda] #1705442
12/02/14 03:30 PM
12/02/14 03:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I currently have the 15X8 w/ 4-1/2" b.s. on my Charger. They fit just fine on my Challenger also. There was no rubbing issues on either car. This was with 295/50/15's though. I didn't want the jacked up look of the taller 275's which is why I went with the 295's. there is a 1" gap with the trim ring. Not one person has ever mentioned or commented that they have ever noticed the gap to me anyway.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
