70 challenger RT
#1705429
12/01/14 12:42 PM
12/01/14 12:42 PM
Posts: 60 Nebraska, USA
David68charger
Nebraska, USA
Ok I have a question for my 70 challenger RT. I would like to put a set of Rallye wheels on my car. So, can I put 15x8 wheels and BFG 275/60/15 on rear and 15x7 235/60/15 on front? If so, will the trim rings fit the 8 inch rim on the back? Is this the factory specs? Thanks for your help. David
Re: 70 challenger RT
[Re: David68charger]
#1705430
12/01/14 03:20 PM
12/01/14 03:20 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
A factory 15x7 trim ring obviously won't fill the complete outboard side of the rim unless the back-spacing is where the additional 1" is. You might find a trim ring for a 15x8 application (like a Corvette trim ring)?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
#1705435
12/01/14 04:26 PM
12/01/14 04:26 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
It seems weird that they would make the 8 inch wheel but not a trim ring that fits correctly.
If they would have made a 8" rally wheel which they did not,they would have a ring to go with it !!
[Re: RJS]
#1705439
12/01/14 09:38 PM
12/01/14 09:38 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Even though Corvettes used 15x8 rims the trim rings were no deeper than ours and left a gap. Ron
[Re: jt4406]
#1705441
12/02/14 12:44 PM
12/02/14 12:44 PM
Posts: 511 South Georgia
tx9cuda
South Georgia
My Challenger has 275's on rear with the 15x7 rallyes, and 245's on the front. 15x8's would likely rub.
1971 BS23H1B
[Re: tx9cuda]
#1705442
12/02/14 03:30 PM
12/02/14 03:30 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I currently have the 15X8 w/ 4-1/2" b.s. on my Charger. They fit just fine on my Challenger also. There was no rubbing issues on either car. This was with 295/50/15's though. I didn't want the jacked up look of the taller 275's which is why I went with the 295's. there is a 1" gap with the trim ring. Not one person has ever mentioned or commented that they have ever noticed the gap to me anyway.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
