Re: Code Cut Chrysler keys by 6bblGT
[Re: JRepucci]
#1704412
11/29/14 02:40 AM
11/29/14 02:40 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
he was also a life saver for me on my old 71 roadrunner. otherwise, I would have had to buy a whole new ignition lock set and they dont just give those away..
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: JRepucci]
#1704413
11/29/14 03:01 AM
11/29/14 03:01 AM
Posts: 553 DE
Ply72rr
DE
1970 ignition key code location
If that is your lock cylinder you might want to take that picture down, it would make a thiefs job awful easy.
[Re: NANKET]
#1704414
11/29/14 03:02 AM
11/29/14 03:02 AM
Posts: 3,116 Sacramento,California
JRepucci
Sounds great, I'm in the same situation. Can you teach us how to remove the lock cylinder from the column without a key? Can Dan use a door lock cyl or truck lock cly be used to make a matching key? Thanks
You have to take the column apart down to the point that you can see the ignition cylinder
[Re: JRepucci]
#1704419
11/29/14 06:41 AM
11/29/14 06:41 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
Great to know. I never knew the code would be on the cylinder. I'm saving this thread
