Code Cut Chrysler keys by 6bblGT #1704409
11/28/14 10:34 PM
11/28/14 10:34 PM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
I bought a 1970 cuda' last summer that came with no ignition/door keys and had been struggling to find a Locksmith to make a new set of keys... Dan Pausch "6bblGT" advertised in the Moparts parts for sale section his ability to cut new keys just from a code... With his help I located the code on the ignition then $35 and a couple of days later I had keys
Thanks Dan
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704410
11/28/14 10:37 PM
11/28/14 10:37 PM
JRepucci Offline OP
JRepucci  Offline OP
1970 ignition key code location
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704411
11/29/14 01:47 AM
11/29/14 01:47 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Sounds great, I'm in the same situation. Can you teach us how to remove the lock cylinder from the column without a key? Can Dan use a door lock cyl or truck lock cly be used to make a matching key? Thanks
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704412
11/29/14 02:40 AM
11/29/14 02:40 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
he was also a life saver for me on my old 71 roadrunner. otherwise, I would have had to buy a whole new ignition lock set and they dont just give those away..
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704413
11/29/14 03:01 AM
11/29/14 03:01 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
If that is your lock cylinder you might want to take that picture down, it would make a thiefs job awful easy.
Re: Code Cut Chrysler keys by 6bblGT [Re: NANKET] #1704414
11/29/14 03:02 AM
11/29/14 03:02 AM
JRepucci Offline OP
JRepucci  Offline OP
You have to take the column apart down to the point that you can see the ignition cylinder
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704415
11/29/14 03:05 AM
11/29/14 03:05 AM
JRepucci Offline OP
JRepucci  Offline OP
There is a small hole that you need to insert a pick or hard wire... Harbor Freight pick set
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704416
11/29/14 03:08 AM
11/29/14 03:08 AM
JRepucci Offline OP
JRepucci  Offline OP
With the pick inserted you need to push this tab down and then push the cylinder out from the inside... If you don't get the tab pushed down far enough and try to push the cylinder out it will not clear the column... push the lock cylinder back in and try again
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704417
11/29/14 03:12 AM
11/29/14 03:12 AM
JRepucci Offline OP
JRepucci  Offline OP
On E body door locks I could not find the EP ####... only found it on the ignition
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704418
11/29/14 03:13 AM
11/29/14 03:13 AM
JRepucci Offline OP
JRepucci  Offline OP
These are door locks from another cuda...
Re: Code Cut Chrysler keys by 6bblGT [Re: JRepucci] #1704419
11/29/14 06:41 AM
11/29/14 06:41 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Great to know. I never knew the code would be on the cylinder. I'm saving this thread
