MP Hemi X-RAM - Intake bolt / Machining Question #1702389
11/23/14 09:51 PM
11/23/14 09:51 PM
USA
SSAAHemiFan Offline OP
USA
I have the MP intake and MP intake bolt kit (P4529330) - all the bolts in the kit are the same length 3"
The countersunk wells inside the intake vary from .210 - .455 deep - with no 2 the same depth
This is causing the exposed length of the bolts to vary from 1/2" to over 1"
I was always told as long as you have thread engagement equal to the diameter of the bolt it is fine ?
Just doesn't look correct to me - So is the machine work off or is the bolt kit incorrect ?
MP didn't put much thought into the kit as 2 of the bolts that don't go thru the inside of the intake are way too long
I wanted to ask before I start modifying anything
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: SSAAHemiFan] #1702390
11/23/14 09:53 PM
11/23/14 09:53 PM
USA
USA
overall pic
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: SSAAHemiFan] #1702391
11/23/14 09:58 PM
11/23/14 09:58 PM
I would look at putting the short ones up front closes to the water pump and the longs one back towards the rear of the block that's the way the original M.W. bolts went in Let us know what you find out and do to take care of this
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: Cab_Burge] #1702392
11/23/14 11:03 PM
11/23/14 11:03 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Send them in and don' cut anything or modify, you'll be fine unless the manifold was milled, you should be good to go.
As long as you don't bottom out you're golden.
Even having 4 or 5 threads showing is fine. If you feel it pulling down you're OK.
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: Sammy] #1702393
11/24/14 12:33 PM
11/24/14 12:33 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, the overpriced MP crossram bolt kit is junk and doesn't fit anything. You are going to have to cut and fit each bolt to each hole. And I would want more than 1/4" of engagement, especially if you have aluminum heads.
2011 Drag Pak Challenger
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: rickseeman] #1702394
11/24/14 05:41 PM
11/24/14 05:41 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You can go to most any bolt supplier and buy 50 to 100 for just a few bucks.Try and buy them with at least 1/4" unthreaded shoulder and cut them to size,try and get 3/8" thread engagement.The high doller MPs with full thread tend to snap just below the heads if thightened to much.Alo you can get them with 5/16 and 1/4 twelve point heads and eliminate the pesky allen heads.
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: B G Racing] #1702395
11/24/14 10:14 PM
11/24/14 10:14 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
It sounds too easy, but look on Granger's web site. They have a great selection of bolts and studs and they are quality pieces, 120,000 lb separation strength, shoulder bolts and studs, etc. I went to them when I studded my inline intake.
Just a suggestion.
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: Hemi ragtop] #1702396
11/25/14 01:47 PM
11/25/14 01:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The biggest problem we find is the seats in the manifold are at diffrent depths.Set the manifold in place and probe each hole in the intake and head for proper length.Do not bottom the bolts in the head as you may pull the threads.The problem with studing the intake is the angle causes binding when trying to install the intake manifold.We usually use two long bolts at the front and back outside corners of the manifold and just start the threads as we lower the manifold to properly position it,then we start all inside ones.
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: B G Racing] #1702397
11/26/14 12:29 AM
11/26/14 12:29 AM
USA
USA
Bob/Rick - Thanks again for the info - especially about the bolts breaking - I guess I am glad they didn't fit
I measured each seperately and will custom cut each one as you suggested - I am going to replace them all with new - quality bolts
Thank Goodness I didn't pay anywhere near the $200 they want now
Re: MP Hemi X-RAM - Intake bolt / Machining Question [Re: SSAAHemiFan] #1702398
11/26/14 09:58 AM
11/26/14 09:58 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We bought a box of 100 grade eight 1/4" bolts with 12 point heads from our local supplier for $39.
