Re: MP Hemi X-RAM - Intake bolt / Machining Question
[Re: SSAAHemiFan]
#1702390
11/23/14 09:53 PM
11/23/14 09:53 PM
Posts: 2,431 USA
SSAAHemiFan
USA
[Re: Cab_Burge]
#1702392
11/23/14 11:03 PM
11/23/14 11:03 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Send them in and don' cut anything or modify, you'll be fine unless the manifold was milled, you should be good to go. As long as you don't bottom out you're golden. Even having 4 or 5 threads showing is fine. If you feel it pulling down you're OK.
[Re: Sammy]
#1702393
11/24/14 12:33 PM
11/24/14 12:33 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Yes, the overpriced MP crossram bolt kit is junk and doesn't fit anything. You are going to have to cut and fit each bolt to each hole. And I would want more than 1/4" of engagement, especially if you have aluminum heads.
2011 Drag Pak Challenger
[Re: B G Racing]
#1702397
11/26/14 12:29 AM
11/26/14 12:29 AM
Posts: 2,431 USA
SSAAHemiFan
USA
Bob/Rick - Thanks again for the info - especially about the bolts breaking - I guess I am glad they didn't fit I measured each seperately and will custom cut each one as you suggested - I am going to replace them all with new - quality bolts Thank Goodness I didn't pay anywhere near the $200 they want now
