Need some belt and pulley help! #1699838
11/17/14 01:03 AM
11/17/14 01:03 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Ok guys, I am having to do an AC delete on my Ramcharger. It was non functioning and the aluminum intake on my replacement engine will not clear any of the AC brackets.
So any of you guys that have either dona an AC delete, or have an AC delete, or NON-AC with power steering on your small blocks please post up some pictures.
Is there a way to use my AC pulleys to make this work, if not what do I need to get my hands on?
I need to source a solution to this so I can get my 4x4 back for winter.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Need some belt and pulley help! [Re: hp383] #1699839
11/17/14 01:53 AM
11/17/14 01:53 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
Had been using this one from an 80's 360 truck. Just not using the ac groove.
Re: Need some belt and pulley help! [Re: magnum440d100] #1699840
11/17/14 01:58 AM
11/17/14 01:58 AM
woodcrest, CA
woodcrest, CA
Then found this one. Not sure why the one groove is smaller, but it allowed me to run a shorter belt and tuck the alternator in
Re: Need some belt and pulley help! [Re: magnum440d100] #1699841
11/17/14 02:14 AM
11/17/14 02:14 AM
woodcrest, CA
woodcrest, CA
Then found this one. Not sure why the one george is smaller, but it allowed me to run a shorter belt and tuck the alternator in
Re: Need some belt and pulley help! [Re: magnum440d100] #1699842
11/17/14 02:20 AM
11/17/14 02:20 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
On this set up what was the belt arrangement?
crank--alt--water pump
crank--water pump--power steering
I found one that showed
crank--power steering
Re: Need some belt and pulley help! [Re: hp383] #1699843
11/17/14 02:27 AM
11/17/14 02:27 AM
woodcrest, CA
woodcrest, CA
On this set up what wat the belt arrangement?
Was it Crank--alt--waterpump
and crank--waterpump--power steering
Front belt was crank-water pump-power steering
Second belt crank-alternator-water pump.
Had that setup so that I had 2 belts running the waterpump so that I one snapped, still had another. Original setup was one belt for alternator/water pump, and the power steering pump had a belt that didn't run over the water pump. Very scary.
Re: Need some belt and pulley help! [Re: hp383] #1699844
11/17/14 09:40 PM
11/17/14 09:40 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
You need that idler set-up like was on my LRE.
Re: Need some belt and pulley help! [Re: redraptor] #1699845
11/17/14 10:03 PM
11/17/14 10:03 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I haven't been able to find one, so now I am looking at what else can be done.
Re: Need some belt and pulley help! [Re: hp383] #1699846
11/17/14 10:27 PM
11/17/14 10:27 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
By your original picture, it looks to me like if you ran on the front pulley on the Alt, your belt alignment might be a little better. Might be the angle of the picture though. Do you have room between the back of the Alt and the head to move that alt behind that top bracket and re-size the spacers to gain belt alignment?
I've also seen where if you can swap the 2 grove Alt pulley for a single grove alt pulley, the belts align pretty close on some applications.
Gene
Re: Need some belt and pulley help! [Re: poorboy] #1699847
11/18/14 03:47 PM
11/18/14 03:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 84 the ac went.I just used shorter belts and adjusted them at the alt.The ac comp just got removed.My belts lined up Ok and I ran it for 3 years with no problems.Rocky
Chrysler Firepower
