Need some belt and pulley help!
#1699838
11/17/14 01:03 AM
11/17/14 01:03 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Ok guys, I am having to do an AC delete on my Ramcharger. It was non functioning and the aluminum intake on my replacement engine will not clear any of the AC brackets.
So any of you guys that have either dona an AC delete, or have an AC delete, or NON-AC with power steering on your small blocks please post up some pictures.
Is there a way to use my AC pulleys to make this work, if not what do I need to get my hands on?
I need to source a solution to this so I can get my 4x4 back for winter.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Need some belt and pulley help!
[Re: magnum440d100]
#1699842
11/17/14 02:20 AM
11/17/14 02:20 AM
hp383
State of Confusion
Had been using this one from an 80's 360 truck. Just not using the ac groove.
On this set up what was the belt arrangement?
crank--alt--water pump crank--water pump--power steering
I found one that showed
crank--alt--water pump crank--power steering
[Re: hp383]
#1699843
11/17/14 02:27 AM
11/17/14 02:27 AM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
On this set up what wat the belt arrangement?
Was it Crank--alt--waterpump
and crank--waterpump--power steering
Front belt was crank-water pump-power steering Second belt crank-alternator-water pump.
Had that setup so that I had 2 belts running the waterpump so that I one snapped, still had another. Original setup was one belt for alternator/water pump, and the power steering pump had a belt that didn't run over the water pump. Very scary.
[Re: redraptor]
#1699845
11/17/14 10:03 PM
11/17/14 10:03 PM
hp383
State of Confusion
I haven't been able to find one, so now I am looking at what else can be done.
[Re: poorboy]
#1699847
11/18/14 03:47 PM
11/18/14 03:47 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
My 84 the ac went.I just used shorter belts and adjusted them at the alt.The ac comp just got removed.My belts lined up Ok and I ran it for 3 years with no problems.Rocky
Chrysler Firepower
