Re: Throttle body ?s
[Re: flyman]
#1693597
11/03/14 01:25 AM
11/03/14 01:25 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Never used one in a rod, but had the misfortune of trying to keep one working properly in its native application.
Run away.
If you are determined to use it, then scrap the stock computer and run a different controller, Megasquirt comes to mind.
[Re: flyman]
#1693602
11/03/14 11:23 PM
11/03/14 11:23 PM
Posts: 19,629 north of coder
moparx
the only one i have done was for my buddys 55 chevy. he used a 95 LT1 with a 700R4 transmission. the controller and harness used was from those guys in mena arkansas. that cost around $1100. i also used a fsm for a 95 cadillac. it uses the same engine, and the wiring scematics came in handy more than once. also, i made a bunch of phone calls to those guys and they were more than glad to help out with my stupid questions. i'm pretty sure they make a harness and controller for a gen 3 hemi now. in my opinion, it is not an easy swap for a person who is marginal in wiring skills. i enjoy wiring, and learned a lot from this experiance. although i told my buddy "i learned stuff i didn't wanna know" being as it was gm related. if you are up for a real challenge, go for it. just remember, ALL connections must be bullet proof, because if they are substandard, you will have no end to chasing gremlins.
[Re: moparx]
#1693603
11/05/14 05:43 PM
11/05/14 05:43 PM
Posts: 28 Montana
DDodger
Montana
lotsa ways to do this wander over to binder planet, 'as right, IHC and read up on adapting GM parts, burning new chips. http://www.binderplanet.com/forums/forumdisplay.php?f=75you can run a Megasquirt ECU and jus use the parts If you want quick and dirty and not necessarily "all that great" the old Holley Pro-Jection stuff will get your feet wet sometimes you find those used
