Throttle body ?s #1693596
11/02/14 06:49 PM
11/02/14 06:49 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Anybody use a late 80,s throttle body in there rods? Willing to share the wiring to make it work?
Re: Throttle body ?s [Re: flyman] #1693597
11/03/14 01:25 AM
11/03/14 01:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Never used one in a rod, but had the misfortune of trying to keep one working properly in its native application.
Run away.
If you are determined to use it, then scrap the stock computer and run a different controller, Megasquirt comes to mind.
Don't be the exception.
Re: Throttle body ?s [Re: flyman] #1693598
11/03/14 01:44 AM
11/03/14 01:44 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The systems from the early-mid 90s (just before the port injection) works much better then the earlier systems.
I have done a few, but it was some time ago and i don't remember, so I'm not much help. I know it was pretty simple if you had the wire harness for the motor & the computer. That system was pretty stand alone, and there were only 6 or 7 wires to connect it to the older cars. I'm running a 90 Dakota system in my coupe, its worked well until the motor went south and the computer tried to compensate for a sick motor. Gene
Re: Throttle body ?s [Re: poorboy] #1693599
11/03/14 10:23 AM
11/03/14 10:23 AM
mn
flyman Offline OP
flyman  Offline OP
mn
Thanks for the Input Poorboy your coup is very nice ride!!
Re: Throttle body ?s [Re: flyman] #1693600
11/03/14 02:40 PM
11/03/14 02:40 PM
dogdays Offline
dogdays  Offline
Don't want to blaspheme, but the GM TBI is very easy to work with and there is a ton of aftermarket support. There are a couple of companies selling them as kits.
R.
Re: Throttle body ?s [Re: dogdays] #1693601
11/03/14 06:01 PM
11/03/14 06:01 PM
mn
flyman Offline OP
flyman  Offline OP
mn
We are working on a budget and trying to run what we have. But I will check it out. Thanks
Re: Throttle body ?s [Re: flyman] #1693602
11/03/14 11:23 PM
11/03/14 11:23 PM
moparx Online content
moparx  Online Content
the only one i have done was for my buddys 55 chevy. he used a 95 LT1 with a 700R4 transmission. the controller and harness used was from those guys in mena arkansas. that cost around $1100. i also used a fsm for a 95 cadillac. it uses the same engine, and the wiring scematics came in handy more than once. also, i made a bunch of phone calls to those guys and they were more than glad to help out with my stupid questions. i'm pretty sure they make a harness and controller for a gen 3 hemi now. in my opinion, it is not an easy swap for a person who is marginal in wiring skills. i enjoy wiring, and learned a lot from this experiance. although i told my buddy "i learned stuff i didn't wanna know" being as it was gm related. if you are up for a real challenge, go for it. just remember, ALL connections must be bullet proof, because if they are substandard, you will have no end to chasing gremlins.
Re: Throttle body ?s [Re: moparx] #1693603
11/05/14 05:43 PM
11/05/14 05:43 PM
Montana
DDodger Offline
DDodger  Offline
Montana
lotsa ways to do this
wander over to binder planet, 'as right, IHC and read up on adapting GM parts, burning new chips.
http://www.binderplanet.com/forums/forumdisplay.php?f=75
you can run a Megasquirt ECU and jus use the parts
If you want quick and dirty and not necessarily "all that great" the old Holley Pro-Jection stuff will get your feet wet sometimes you find those used
Re: Throttle body ?s [Re: DDodger] #1693604
11/05/14 11:14 PM
11/05/14 11:14 PM
speaking of those holley pro-jection units. i got one of those at a swap meet several years ago just to play around with. it sure is a basic setup. i just haven't had time, nor the right project, to see if it's anything viable. i got it on the cheap, so if it doesn't work out, i'm not out much.
