Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Why do guys race small blocks? [Re: Chris'sBarracuda] #1692090
10/31/14 02:00 AM
10/31/14 02:00 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I shift my junk at 9400. I have less than 7k in this engine. Haven't changed a single part yet. Checked bearings every year and they still had coating on them. Now that there is over 5000 miles on it, I'm tearing it down this winter and refreshing the heads and rings.
Even with the Ti valves it'll cost less than $700 to do the heads
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Why do guys race small blocks? [Re: Chris'sBarracuda] #1692091
10/31/14 03:17 AM
10/31/14 03:17 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Lee car went 6.90's in testing with the new BRE bullet, ran 7.018 on it's first pass in the car.
Alan Jones
Re: Why do guys race small blocks? [Re: Gary Robbins] #1692092
10/31/14 08:07 AM
10/31/14 08:07 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I love to play with smallblocks...Come get ya some !!
Show me any street legal smallblock MOPAR in the 4'S in the 1/8 or 7'S on the 1/4 ??
There is none. But when Chad gets his w8 turbo deal done I am sure he would race ya!
Come on Brad you can do better than that ...Outlaw big turbo car against mine ...They don't even allow boost on bigblocks in what I'm racing
And how much nitrous are you feeding your baby?
Not as much as most or what you think...What's that got to do with anything anyway ??? N/A cars will never keep up with power adder cars as HP is HP any way you figure it !!!
For a lot of us it has everything to do with it.
I have 4 other cars from 8 second to 12 second quarter mile cars all N/A and none compare to low teen 60' at 3250# on a 275 drag radial...Besides if ya think it's easy come give it a try as the water is only luke warm and so easy even a HILLBILLY from Oklahoma can do it !!
What class?
Re: Why do guys race small blocks? [Re: ademon] #1692093
10/31/14 09:51 AM
10/31/14 09:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"Does he race the car? Like really race it not once or twice a year. I know of a w8 motor right now you can buy for 5000. You need to know where to look."
plus what does one need for W8? how much stall? Gear? Most BB need 4000-4500 max. You can run 10's w/ 4.10's and you don't need to rev the tar out of it. The engine I have w/ a good intake and Dominator would run low 10's easy in an A-body w/ a 4000 stall and 4.10's. I could drive it 60 miles race and drive it home. I paid 3k for it valley pan to oil pan.
I don't know about low 10's with your motor, your only running mid 11's now! I will agree you would be faster in a tricked out 70 duster or something. Which brings us to the meat of the post your running 11's with a bb and some with sb are running 8's and 9's, are you wanting to pull your motor and stick it in a A body? Probably not, just like guys that are happy running whatever et with a SB couldn't care less about going to a BB.
My setup is far from prefect as it sits. The six-pack is a limiting factor as well as the stall and gear. I haven't even got a run w/ the cal-tracs yet nor have I messed w/ the outboards. Again this is a freshened up motor w/ a bunch of used parts. The SBs you are talking about are all out race motors and cost double or triple what I have and would never run close to 8's or 9's in a 3800lb car. And I have done the B to A body swap. I had a nice 383 that ran 13.20's (spinning)in a full steel 69 Charger, nothing special .030 over 10:1 383, ported 915 heads w/ 1.81, 2.14 valves, 509 cam, headers, torker II, 750DP...usual early 90's build pulled the motor stuck it in a 68 dart (gutted no inner fenders, gutted hood), and it ran 11.98 w/ a suspect trans. Car would have run easy 11.50's w/ a good trans. So I know what a lighter car will do.
$ for $ you won't beat a BB wedge. Sure you can spend a ton of money on a race SB or Hemi but for most of us here those are not options.
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692094
10/31/14 09:55 AM
10/31/14 09:55 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Bottom 5s is all I know of. If I shead enough weight and push mine off a cliff I might get close to 4s.
all over my keyboard!!!!!
Lets see 32 feet per second per second equals 183 mph depending on altituted
You'll need an airbag Matt
Re: Why do guys race small blocks? [Re: MattW] #1692095
10/31/14 10:06 AM
10/31/14 10:06 AM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
1. Because all I do is occasionally bracket race and TNT.
2. Its all I have.
3. SB's are are what I have worked on the most
That about sums it up
Re: Why do guys race small blocks? [Re: Mr.Yuck] #1692096
10/31/14 10:46 AM
10/31/14 10:46 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Just plugged my motor in your 3800 pound car, wallace spit out 8.94@151. R5P7 Duster has 7000 in his and goes mid nines na where are you getting a big block with type of parts in it for that money? Your not going too. Why do your examples keep getting slower? First you said mid nines, then mid tens now we are all the way down to mid 11s, big difference in those times.
I used to have factory 340 block, mp 3.65 stroke crank(close out 550 new) edelbrock rpms, eagle rods, m1 intake and off the shelf crowler roller. Low dollar motor ran on pump gas and went mid tens na and mid nines on the bottle.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692097
10/31/14 11:02 AM
10/31/14 11:02 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You SB guys are comparing apples to onions. You are not going to take a stock 340-360 block and an a summit catalog and build a 9 second motor. (w/o boost or N2O) However you CAN do that with a BB wedge. The r5p7 motor is a freakin' NASCAR engine and the W8 is an all out race motor. If you want to spin it, One could take a KB all aluminum Hemi and run 6's w/ your logic.
The 11 second thing was me explaining I have done the B to A body BB swap and the car was much faster (as expected) with the same motor. That motor I got fresh off the stand intake to oil pan for $500 (I wish I could find that kind of deal again) Of course that was 1992-93.
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692098
10/31/14 11:06 AM
10/31/14 11:06 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Alright, how fast can I go with an NA pump gas small block that I can run on the street with a 4 speed and 4.56s in my 3700 lb car for 7k?
Re: Why do guys race small blocks? [Re: Mr.Yuck] #1692099
10/31/14 11:29 AM
10/31/14 11:29 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hello he paid $7000 for his motor, I dont care who built it. Can you get a aluminum hemi for 7000? maybe the block lol. Goes mid nines NA with a 358 small block. Whats your summit motor for 7000 that will go mid nines.
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692100
10/31/14 11:46 AM
10/31/14 11:46 AM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
I've got nothing against little blocks as I have a 400+ eddy headed smallblock Duster streeter and a nice w headed 400+ setting in the floor...Besides,my next build will be a turbo smallblock w headed or gen3 Hemi
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692101
10/31/14 12:07 PM
10/31/14 12:07 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Talking used motors? Indy Maxx low deck aluminum block, with Indy -1 heads, jesel rockers, roller cam, 512 inches dominator to dragster pan and dual line oiling system. 10,500. Slid it right in where my Eddie headed 440 came out. No need for custom adapters, or high dollar 7 inch converters.
I spent 9800 on my small block, and I already had the X block, rockers, pan, valve covers. I'm happy with it so far. If it was a BB, I'd know exactly how much N20 I could hit it with, and how many passes I could abuse it, before it needed freshened, the small block...I don't...yet. The fear of the unknown makes me nervous!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Why do guys race small blocks? [Re: Gary Robbins] #1692102
10/31/14 12:08 PM
10/31/14 12:08 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My first hit of fun began with a 340 in my Mirada. It went from mild, to 6pak, to 4bbl with a NOS plate. About 93 we build our low buck RB stroker and put that in. That incarnation ended up running into the 9's at sea level over years of tweeking and upgrading..... but launch at 3400, shift at 5800, trap at 6200 was kind of s snoozer. It was waayyy more fun going back to SoDak and wheeling my dads W5 powered Duster. Even short shifting at 6800 that lil car would haul the mail. Big block car is gone..... so I'm back to where I prefer to be. A nice lowbuck iron head 360 that will run 10.8 in Vegas, and our W8 small block is residing between the fenders now awaiting it's first trek to the track. For the money I have in the W8 I'm sure I could have built more power with a big block package, but maybe not.... Either way, I love my small blocks!
Re: Why do guys race small blocks? [Re: J_BODY] #1692103
10/31/14 02:04 PM
10/31/14 02:04 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Small block NA
Re: Why do guys race small blocks? [Re: W5DART66] #1692104
10/31/14 02:22 PM
10/31/14 02:22 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Simple answer to this question..........POWER is directly rated to air flow.......flow more air, make more power. Now the question to the question, is how much power you want to make.
If your goal is 700hp or less, either can easily do it, with the smallblock in this range only required to be slightly more exotic to achieve these numbers. And in a weight for weight car, the small motor should be quicker because of lighter engine.
If 800hp is what you want, both can still easily do it, but the big block gets more costly and the smallblock gets REALLY costly.
If 900 is your goal, this is big block land......... NOT saying a smallblock won't make 900, it will. But at that level the 900hp small motor will cost WAY more than the 900hp big block and be less reliable.
If you want a good bit over 900hp, this is big block land......PERIOD
Monte
Re: Why do guys race small blocks? [Re: Monte_Smith] #1692105
10/31/14 03:38 PM
10/31/14 03:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Monte
Is this for na motors? Or would you consider this for power adder motors too.
Re: Why do guys race small blocks? [Re: fishy340] #1692106
10/31/14 04:13 PM
10/31/14 04:13 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
MOPAR Pro Stock Chrysler Australia: http://youtu.be/qKSuJ05kclM
And there is a faster one built by Bob Book using Slawko heads...This is why we like sb's
Love everything prostock,doenst mather if its 400 or 500 cui.
Except they make me feel inferior,makes me feel less capable,worth less.
i hate the obivous fact that some people have alot more talent.
Re: Why do guys race small blocks? [Re: GTX MATT] #1692107
10/31/14 04:40 PM
10/31/14 04:40 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re: Why do guys race small blocks? [Re: 72Swinger] #1692108
10/31/14 05:16 PM
10/31/14 05:16 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
BB's and Hemi's were all the rage forever until the W8 came along.
Don't get me wrong. I'm a die hard BB guy. I'm not well versed in the SB area. So I'm going to ask a dumb question here.....
So what is this W8 thing all about. I'm just curious
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Why do guys race small blocks? [Re: 1320Dart] #1692109
10/31/14 05:49 PM
10/31/14 05:49 PM
P
Paul_Fancsali Offline
P
Race what you want but back in day of the late 60s and early 70s I looked for 440 and hemi powered cars to race with my 340 Duster on the street. Most of the hemi's in particular were less then spectacular. I raced several Hemi powered cars on street and won. I was running modified dist and carb nothing else and I could really shift a 4 speed. Now I watch the new Hemi cars in 11s or better so trying to compare the old big blocks and small blocks ? why race a old Hemi when the new hemi one will be a winner stock? Face it times are changing and the cars are just plain faster , but that doesn't stop me from racing the new ones too If they are supercharged I say nitrous! But do what you want !!
