Re: Tire tread separation question
[Re: Jopar]
#1690518
10/25/14 10:47 PM
10/25/14 10:47 PM
Challenger 1
Cincinnati, Ohio
I noticed a vibration and want your opinion on potential cause. I have attached a picture and suspect the the tire is bad. Take a look and let me know your thoughts. It looks like the tread is starting to separate from the outer sidewall.
What's the date code on the side of the tire? Post it up here and we'll tell how old the tire is. I suspect that is your problem. Like you already know.
[Re: Jopar]
#1690520
10/26/14 12:18 AM
10/26/14 12:18 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
When the belt breaks, an "egg" can form that will thump. The tire is probably (very) near the end. Better to retire ( ) it now before it decides to take out a rim or fender (or worse).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: buildanother]
#1690522
10/26/14 05:58 AM
10/26/14 05:58 AM
Posts: 1,805 ky hills
thehemikid
ky hills
Looks to me like the tire has been biting the fender lip possibly, causing the carnage. Vibration from elsewhere?
Fender lip. X2
[Re: Jopar]
#1690525
10/26/14 01:30 PM
10/26/14 01:30 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Looks like mentioned, it has rubbed somewhere at some point. It could have put a small slice in it then cracked and got bigger over time.
It doesn't take much weight missing to cause a vibration, like it a 1/4 ounce wheel weight fell off... so it very well could be why your noticing it now.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
