Tire tread separation question #1690515
10/25/14 10:16 PM
10/25/14 10:16 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
I noticed a vibration and want your opinion on potential cause. I have attached a picture and suspect the the tire is bad. Take a look and let me know your thoughts. It looks like the tread is starting to separate from the outer sidewall.
Re: Tire tread separation question [Re: Jopar] #1690516
10/25/14 10:31 PM
10/25/14 10:31 PM
Kirkland, Washington
Pacnorthcuda Offline
Good eye! I would watch that. If it gets worse do something about it. On the front that's a high stress area on the tire. Can you move it to the back?
Re: Tire tread separation question [Re: Jopar] #1690517
10/25/14 10:42 PM
10/25/14 10:42 PM
But I do not think that would cause any vibration, unless there is serious tread separation going on, which you could check by rotating the tire so the area is very close to the ground and inspect to see if there is odd movement (separation) from the belts of the tire.
Re: Tire tread separation question [Re: Jopar] #1690518
10/25/14 10:47 PM
10/25/14 10:47 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What's the date code on the side of the tire? Post it up here and we'll tell how old the tire is. I suspect that is your problem. Like you already know.
Re: Tire tread separation question [Re: Challenger 1] #1690519
10/25/14 11:50 PM
10/25/14 11:50 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
UDN 127 I assume this means 12th week of 97. Time to replace...
Re: Tire tread separation question [Re: Jopar] #1690520
10/26/14 12:18 AM
10/26/14 12:18 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
When the belt breaks, an "egg" can form that will thump. The tire is probably (very) near the end. Better to retire ( ) it now before it decides to take out a rim or fender (or worse).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Tire tread separation question [Re: Jopar] #1690521
10/26/14 02:58 AM
10/26/14 02:58 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks to me like the tire has been biting the fender lip possibly, causing the carnage. Vibration from elsewhere?
Re: Tire tread separation question [Re: buildanother] #1690522
10/26/14 05:58 AM
10/26/14 05:58 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Fender lip. X2
Re: Tire tread separation question [Re: thehemikid] #1690523
10/26/14 01:08 PM
10/26/14 01:08 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
Verified this morning that the damage is about 2/3 the diameter of tire. Also confirmed that the fender lip is nowhere near damage. I think I am going with tire is bad.
Re: Tire tread separation question [Re: Jopar] #1690524
10/26/14 01:19 PM
10/26/14 01:19 PM
Cincinnati, Ohio
Cincinnati, Ohio
When you go to take it off, jack it up to where it's just barely clearing the ground and spin the tire to if it's out of round.
Re: Tire tread separation question [Re: Jopar] #1690525
10/26/14 01:30 PM
10/26/14 01:30 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Looks like mentioned, it has rubbed somewhere at some point. It could have put a small slice in it then cracked and got bigger over time.
It doesn't take much weight missing to cause a vibration, like it a 1/4 ounce wheel weight fell off... so it very well could be why your noticing it now.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Tire tread separation question [Re: Silver70] #1690526
10/26/14 01:39 PM
10/26/14 01:39 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It looks like cuts to me (and I have to inspect tires daily). It's a moot point anyway those are too old to be driving on. Of course you want to know what it rubbed on before mounting new tires though, which I can understand.
Sheldon
Re: Tire tread separation question [Re: RUNCHARGER] #1690527
10/26/14 04:25 PM
10/26/14 04:25 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Have you rotated tire lately, maybe it caught on the other lip?
Re: Tire tread separation question [Re: thehemikid] #1690528
10/26/14 08:30 PM
10/26/14 08:30 PM
Maryland
gofastboater Offline
Maryland
If they are from '97 it's a NO-BRAINER. Replace them. Don't try to make excuses. Why take the chance. It's not worth the possible damage.
Re: Tire tread separation question [Re: gofastboater] #1690529
10/26/14 08:36 PM
10/26/14 08:36 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Tires are cheaper than paint and bodily harm. Replace them or stop driving the car especailly fast enough to feel a vibration.
Careful, your character's showing!
