Track racing question
#1686199
10/15/14 12:27 PM
10/15/14 12:27 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Going to take Road runner to track again this weekend and plan on doing a few onsite adjustments First off I plan on dis connecting the front sway bar.. Do I need to disconnect both sides or just one side to make inoperable? Second I run 275/60-15 nitto drag radials, I am thinking about running 15 psi of pressure, is that two low? Finally I for a set of Rancho adjustable shocks for back with 9 settings. I run 3600 SS springs, what I have read on here is most guys like it at setting 7, 8 for stiffness? Is that a good ball park Here is the ride again 1972 road runner with mild 440 in it, and ayto transmission.. I got 90/10 shocks up front, and the rest is stock. Back super stock springs, pinion snubber and Rancho shocks ![](/ubbthreads/images/graemlins/flame.gif) Thanks in advance Mikey
1969 Dodge Dart Swinger
Re: Track racing question
[Re: MikeyT]
#1686201
10/15/14 01:05 PM
10/15/14 01:05 PM
Triple Threat
Renton Washington
Unhook both sides, 16-18# of air and 7 is probably an ok starting point on the shocks.
Have fun!
[Re: Mr.Yuck]
#1686202
10/15/14 01:39 PM
10/15/14 01:39 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
If you are going to unhook the sway bar do both sides. I tried it once on a mild 440 (12.90 in a 3850lb car) and it didn't do anything. 15lbs in a drag radial is to low. Try 22 to start with. No idea on the shocks, but w/ the SS springs you won't need the snubber. What are you shooting for?
X2 on the no snubber. Footbraking you will not touch it. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moparguy7074]
#1686203
10/15/14 01:47 PM
10/15/14 01:47 PM
MikeyT
Watertown, WI
Thanks guys
Hoping to hit 1.7 on 60 foot best so far 2.0
Mike
[Re: MikeyT]
#1686204
10/15/14 02:14 PM
10/15/14 02:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks guys
Mike
what is your set-up? engine? converter?
[Re: Mr.Yuck]
#1686205
10/15/14 03:12 PM
10/15/14 03:12 PM
MikeyT
Watertown, WI
mild 440 (9;1 comp) Holley street dominator intake 750 QFT slayer carb 915 heads with bigger valves and slight prot job Voodoo 703 cam TTi headers 1 7/8 uncorked
Automatic with 9.5 PTC 3600 stall converter
mikey
[Re: MikeyT]
#1686206
10/15/14 03:41 PM
10/15/14 03:41 PM
Mr.Yuck
Brookeville, Md
mikey
Should run mid-high 12's w/ a 1.65 or so sixty foot.
[Re: Mr.Yuck]
#1686207
10/15/14 04:20 PM
10/15/14 04:20 PM
MikeyT
Watertown, WI
Hope So, what would be a good launch rpm? It has 3.55 gears so I plan on shifting early like 5200 to maximize top end hp
[Re: Cab_Burge]
#1686209
10/16/14 12:20 AM
10/16/14 12:20 AM
MikeyT
Watertown, WI
That is the plan Cab, my friend! ![](/ubbthreads/images/graemlins/drive.gif) I figure this could be some fun experimenting!
