Track racing question #1686199
10/15/14 12:27 PM
10/15/14 12:27 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Going to take Road runner to track again this weekend and plan on doing a few onsite adjustments
First off I plan on dis connecting the front sway bar.. Do I need to disconnect both sides or just one side to make inoperable?
Second I run 275/60-15 nitto drag radials, I am thinking about running 15 psi of pressure, is that two low?
Finally I for a set of Rancho adjustable shocks for back with 9 settings. I run 3600 SS springs, what I have read on here is most guys like it at setting 7, 8 for stiffness? Is that a good ball park
Here is the ride again 1972 road runner with mild 440 in it, and ayto transmission.. I got 90/10 shocks up front, and the rest is stock. Back super stock springs, pinion snubber and Rancho shocks
Thanks in advance
Mikey
1969 Dodge Dart Swinger
Re: Track racing question [Re: MikeyT] #1686200
10/15/14 12:56 PM
10/15/14 12:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you are going to unhook the sway bar do both sides. I tried it once on a mild 440 (12.90 in a 3850lb car) and it didn't do anything.
15lbs in a drag radial is to low. Try 22 to start with. No idea on the shocks, but w/ the SS springs you won't need the snubber. What are you shooting for?
Coming soon!!!!
Re: Track racing question [Re: MikeyT] #1686201
10/15/14 01:05 PM
10/15/14 01:05 PM
Renton Washington
Triple Threat Offline
Renton Washington
Unhook both sides, 16-18# of air and 7 is probably an ok starting point on the shocks.
Have fun!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Track racing question [Re: Mr.Yuck] #1686202
10/15/14 01:39 PM
10/15/14 01:39 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
X2 on the no snubber. Footbraking you will not touch it.
Re: Track racing question [Re: moparguy7074] #1686203
10/15/14 01:47 PM
10/15/14 01:47 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks guys
Hoping to hit 1.7 on 60 foot best so far 2.0
Mike
Re: Track racing question [Re: MikeyT] #1686204
10/15/14 02:14 PM
10/15/14 02:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks guys
Mike
what is your set-up? engine? converter?
Re: Track racing question [Re: Mr.Yuck] #1686205
10/15/14 03:12 PM
10/15/14 03:12 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
mild 440 (9;1 comp)
Holley street dominator intake
750 QFT slayer carb
915 heads with bigger valves and slight prot job
Voodoo 703 cam
TTi headers 1 7/8 uncorked
Automatic with 9.5 PTC 3600 stall converter
mikey
Re: Track racing question [Re: MikeyT] #1686206
10/15/14 03:41 PM
10/15/14 03:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
mild 440 (9;1 comp)
750 QFT slayer carb
Voodoo 703 cam
mikey
Should run mid-high 12's w/ a 1.65 or so sixty foot.
Re: Track racing question [Re: Mr.Yuck] #1686207
10/15/14 04:20 PM
10/15/14 04:20 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hope So, what would be a good launch rpm? It has 3.55 gears so I plan on shifting early like 5200 to maximize top end hp
Re: Track racing question [Re: MikeyT] #1686208
10/15/14 11:58 PM
10/15/14 11:58 PM
If you can get enough runs, try moving the shift RPM up and down in both 1st and 2nd gear Look at the 60 ft., 330 and 660 times Use what works best
Re: Track racing question [Re: Cab_Burge] #1686209
10/16/14 12:20 AM
10/16/14 12:20 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
That is the plan Cab, my friend!
I figure this could be some fun experimenting!
