Indy -13 tunnel ram #1684884
10/12/14 07:38 PM
10/12/14 07:38 PM
griff70440 Offline OP
Hi Guys
who has the best prices on indy tunnel rams? does anyone have a used one the want to sell?
Thanks,
Mike
Re: Indy -13 tunnel ram [Re: griff70440] #1684885
10/13/14 12:32 AM
10/13/14 12:32 AM
For those of us who do not know part numbers what motor and carb. top are you looking for?
Re: Indy -13 tunnel ram [Re: Cab_Burge] #1684886
10/13/14 01:18 AM
10/13/14 01:18 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
they are $850 new from indy
there was a guy last mounth that had one for sale $200
R/B is more common
1.39 9.85 - 137 mph
Re: Indy -13 tunnel ram [Re: Ari440] #1684887
10/13/14 07:48 AM
10/13/14 07:48 AM
pa
572charger Offline
572charger  Offline
pa
i have a hemi indy tunnel ram i would sell !!! also got carbs and fogger system on it !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Indy -13 tunnel ram [Re: 572charger] #1684888
10/13/14 11:23 AM
10/13/14 11:23 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Once you get used to tuning with a Tunnel-Ram(which is very simple) you will never go back to a single carb. intake.Purchasing a Tunnel-Ram will be $$$ well spent its worth the extra $$$ just for the looks if nothing else.
PS I would not answer your question if I did not run them myself!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy -13 tunnel ram [Re: Cab_Burge] #1684889
10/13/14 01:05 PM
10/13/14 01:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
For those of us who do not part numbers what motor and carb. top are you looking for?
What he said
Re: Indy -13 tunnel ram [Re: B G Racing] #1684890
10/14/14 09:48 AM
10/14/14 09:48 AM
The motor is a 572.
mega block
Bryant crank
572-13 heads /jesel rocker
wiseco pistons / Bill Miller rods
820 lift rolller / jesel belt
Carbs are 1050 domantors
Re: Indy -13 tunnel ram [Re: griff70440] #1684891
10/16/14 08:53 AM
10/16/14 08:53 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Then your looking for a 440-14-15 manifold.
Re: Indy -13 tunnel ram [Re: B G Racing] #1684892
10/16/14 09:06 AM
10/16/14 09:06 AM
Re: Indy -13 tunnel ram [Re: griff70440] #1684893
10/16/14 04:33 PM
10/16/14 04:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Re: Indy -13 tunnel ram [Re: griff70440] #1684894
10/17/14 05:47 PM
10/17/14 05:47 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
What kind of gain over the single 4...
Mopar Performance
Re: Indy -13 tunnel ram [Re: moparniac] #1684895
10/17/14 07:58 PM
10/17/14 07:58 PM
I saw thirty HP using a Indy cast RB M.W. port size tunnel ram intake with two 1050 Dominators over using Indys 440-3 intake with a single 1050 Dominator I was hoping for more
Re: Indy -13 tunnel ram [Re: Cab_Burge] #1684896
10/18/14 02:32 PM
10/18/14 02:32 PM
Penna
70satelliteguy Offline
Penna
"I saw thirty HP using a Indy cast RB M.W. port size tunnel ram intake with two 1050 Dominators over using Indys 440-3 intake with a single 1050 Dominator I was hoping for more "
Cab Burge: Was that on a 572 motor with the 572-13 heads???
Mike
Re: Indy -13 tunnel ram [Re: 70satelliteguy] #1684897
10/18/14 02:47 PM
10/18/14 02:47 PM
Mike
No, it was a 526 C.I.(4.380 x 4.375 stroke) 440 block with a set of 440-1 CNC ported by MCH that flowed 370 CFM at .600 and up on the lift That motor with a set of Indy SR M.W. ports and the same carb. and intake made 50 HP less than with the 440-1 CNC ported with no other changes. I swapped both sets of those heads on my 518 C.I. pump gas motor on the same dyno two weeks apart and it made 50 HP more with the 440-1 heads The extra 1050 didn't make as much difference as I expected It did what it did BTW, I have seen several high dollar race BB Chevy tunnl ram motors that have a different jet size in each barrel of both carbs Maybe I should use the EGT readings, going fatter first, to jet instead of changing all eight jets at once Maybe that will be one of my next dyno testing test
Re: Indy -13 tunnel ram [Re: Cab_Burge] #1684898
10/18/14 05:23 PM
10/18/14 05:23 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
big block chevys have good ports and bad ports ,that is why its stagerd jetting in them
a 1050 went 9.91
two 750 on a tunnelram went 9.85
have not tried out the two 1050 yet
do you think it might be overkill ?
1.39 9.85 - 137 mph
Re: Indy -13 tunnel ram [Re: Ari440] #1684899
10/19/14 01:34 AM
10/19/14 01:34 AM
Every BB wedge motor I have raced at the track like more air It didn't matter if it was carb size, camshaft, headers or better mainfold and better carbs I would try the bigger carbs. as long as the fuel suystem will keep up BTW, did you ever try that Weiand six pak intake agianst a stock six pak intake? If so how much difference was there
Re: Indy -13 tunnel ram [Re: Cab_Burge] #1684900
10/19/14 03:00 AM
10/19/14 03:00 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
the weiand was better then the indy modman , same carbs on my roadrunner , streetcar no track time
1.39 9.85 - 137 mph
