Re: W-2 porting, are these junk or good?
[Re: RUNCHARGER]
#1684649
10/12/14 12:39 AM
10/12/14 12:39 AM
Posts: 4,457 Washington
madscientist
Washington
The bowl is the most important part of it. After flowing literally hundreds of ports like that, I either leave them oval or make them square. Just make sure if you leave them alone (and you should) that your intake exactly matches the port.
I would also make sure they didn't machine the guide boss away. Big flow killer if they did.
[Re: Diplomat360]
#1684652
10/12/14 04:15 AM
10/12/14 04:15 AM
Posts: 792 Earth
Rob C
Earth
Weren't the early W2 actual rectangle ports? Once in a while you still come across them...or the intakes...
The W2 has been a oval port head since they were born in the 70's. No such thing as a rectangle port W2 head from the factory.
Some porters have made them into rectangles.
[Re: cudadoug]
#1684654
10/12/14 12:06 PM
10/12/14 12:06 PM
Posts: 207 warren, mich.
dwayne welder
warren, mich.
Sheldon, Look to see anywere on the head, on the ends to see who could have ported them!!!! I use to work at Diamond Racinr Engines, here in Warren Mi. Those could have come from there!! Butch Elkins designed that head for Mopar, back in the day!!! They started life off the, "T/A", Head!! Let us know, Thanks!!! Dwayne
