W-2 porting, are these junk or good? #1684645
10/11/14 10:32 PM
10/11/14 10:32 PM
Chilliwack B.C. Canada
RUNCHARGER Offline OP
Just picked up some W-2's, wondering if they are wrecked or if they might work?
Sheldon
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684646
10/11/14 10:33 PM
10/11/14 10:33 PM
Another. Most likely done decades ago.
Sheldon
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684647
10/11/14 10:37 PM
10/11/14 10:37 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Is that epoxy in one port?
Looks like some tried to copy Bob Lambeck pro stock head. Matt
Re: W-2 porting, are these junk or good? [Re: MattW] #1684648
10/11/14 11:08 PM
10/11/14 11:08 PM
No epoxy, yet. It does look like really old technology. The workmanship is really good so I suppose it was state of the art for whatever decade it was. They're going onto my son's 360 in his 2500lb Datsun but they look like they'd be happier with some more cubes to feed. I'm glad his car is light anyway.
Sheldon
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684649
10/12/14 12:39 AM
10/12/14 12:39 AM
Washington
madscientist Offline
Washington
The bowl is the most important part of it. After flowing literally hundreds of ports like that, I either leave them oval or make them square. Just make sure if you leave them alone (and you should) that your intake exactly matches the port.
I would also make sure they didn't machine the guide boss away. Big flow killer if they did.
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684650
10/12/14 01:08 AM
10/12/14 01:08 AM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
Weren't the early W2 actual rectangle ports? Once in a while you still come across them...or the intakes...
Re: W-2 porting, are these junk or good? [Re: Diplomat360] #1684651
10/12/14 01:30 AM
10/12/14 01:30 AM
Yep the intake matches right now and the guide bosses are there.
Sheldon
Re: W-2 porting, are these junk or good? [Re: Diplomat360] #1684652
10/12/14 04:15 AM
10/12/14 04:15 AM
Earth
Rob C Offline
Rob C  Offline
Earth
The W2 has been a oval port head since they were born in the 70's.
No such thing as a rectangle port W2 head from the factory.
Some porters have made them into rectangles.
Re: W-2 porting, are these junk or good? [Re: Rob C] #1684653
10/12/14 04:27 AM
10/12/14 04:27 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
One way to know for sure: flow bench.
Re: W-2 porting, are these junk or good? [Re: cudadoug] #1684654
10/12/14 12:06 PM
10/12/14 12:06 PM
warren, mich.
dwayne welder Offline
warren, mich.
Sheldon, Look to see anywere on the head, on the ends to see who could have ported them!!!! I use to work at Diamond Racinr Engines, here in Warren Mi. Those could have come from there!! Butch Elkins designed that head for Mopar, back in the day!!! They started life off the, "T/A", Head!! Let us know, Thanks!!! Dwayne
Re: W-2 porting, are these junk or good? [Re: dwayne welder] #1684655
10/12/14 12:58 PM
10/12/14 12:58 PM
Thanks Dwayne, I'll check them closer today. The work is really high quality so I do believe they came from a big shop all right.
Sheldon
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684656
10/12/14 10:40 PM
10/12/14 10:40 PM
No stampings from Diamond or anywhere else for that matter. Heads were cast in 77 so the porting is likely old as dirt as well.
Sheldon
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684657
10/12/14 11:48 PM
10/12/14 11:48 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
You're lucky. I cant cant believe this hasn't turned into a gen 3 thread yet. All smallblock threads normally do. They must be sleeping.
Re: W-2 porting, are these junk or good? [Re: Hot 340] #1684658
10/12/14 11:52 PM
10/12/14 11:52 PM
Yep: Either that or why we shouldn't care and just run a Chevy because they are so much better than our stuff.
Sheldon
Re: W-2 porting, are these junk or good? [Re: RUNCHARGER] #1684659
10/13/14 12:04 AM
10/13/14 12:04 AM
Washington
Washington
Sheldon
Clean them, touch up the seats, check the guides, a light surface and go.
Re: W-2 porting, are these junk or good? [Re: madscientist] #1684660
10/13/14 12:10 AM
10/13/14 12:10 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
And torque those down in small increments. The newer versions have reinforcing ribs around the lower head bolt holes for a reason.
Re: W-2 porting, are these junk or good? [Re: madscientist] #1684661
10/13/14 12:36 AM
10/13/14 12:36 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pressure test then flow test and see were you stand. Should cost you 100-125 dollars est.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W-2 porting, are these junk or good? [Re: pittsburghracer] #1684662
10/13/14 01:50 AM
10/13/14 01:50 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Good idea PittsburghRacer.
