Need measurment; Hemi Cuda or Chalenger w/ Shaker
#1684048
10/09/14 08:09 PM
10/09/14 08:09 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I need to know the distance from the crank centerline of a Hemi (Gen 2) to the carb base, and to the top of the shaker assembly. I am hoping to adapt this system to a Gen 3 project. Thanks Greg
Re: Need measurment; Hemi Cuda or Chalenger w/ Shaker
[Re: second 70]
#1684050
10/10/14 08:27 PM
10/10/14 08:27 PM
gregsdart
Thanks, Mike! Do you know how high above the carb air cleaner mounting surface the top of the air cleaner is? With all these measurments, I should be able to figure out if it will ll fit under that 65 Dart!
