Need measurment; Hemi Cuda or Chalenger w/ Shaker #1684048
10/09/14 08:09 PM
10/09/14 08:09 PM
gregsdart Online content OP
gregsdart  Online Content OP
I need to know the distance from the crank centerline of a Hemi (Gen 2) to the carb base, and to the top of the shaker assembly. I am hoping to adapt this system to a Gen 3 project. Thanks Greg
Re: Need measurment; Hemi Cuda or Chalenger w/ Shaker [Re: gregsdart] #1684049
10/10/14 05:20 PM
10/10/14 05:20 PM
central il.
second 70 Offline
second 70  Offline
central il.
Good timing Greg I just switched from 90/10 to 100% gas and needed to lean out my carbs.
Ok the numbers I got were from centerline of crank to the top outside of the shaker was 23" and from the carb base plate (where air cleaner fits) no gasket to centerline is 19".
This is on a 1970 cuda with a stage V 2-4 manifold with edelbrock carbs. The manifold is around a 1/4" taller than a stock manifold.
The shakers look cool but are a real pain to work around and they hold in a lot of heat on the carbs.
Mike
Re: Need measurment; Hemi Cuda or Chalenger w/ Shaker [Re: second 70] #1684050
10/10/14 08:27 PM
10/10/14 08:27 PM
Thanks, Mike! Do you know how high above the carb air cleaner mounting surface the top of the air cleaner is? With all these measurments, I should be able to figure out if it will ll fit under that 65 Dart!
Re: Need measurment; Hemi Cuda or Chalenger w/ Shaker [Re: gregsdart] #1684051
10/10/14 09:37 PM
10/10/14 09:37 PM
central il.
second 70 Offline
second 70  Offline
central il.
I knew I shouldn't have put it all back together! Lol
From the base of carb to raised center of top of air cleaner is around 2 1/2".
Re: Need measurment; Hemi Cuda or Chalenger w/ Shaker [Re: second 70] #1684052
10/10/14 10:59 PM
10/10/14 10:59 PM
Thanks a lot, that gives me all the info!
Re: Need measurment; Hemi Cuda or Chalenger w/ Shaker [Re: gregsdart] #1684053
10/10/14 11:10 PM
10/10/14 11:10 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
If you do a google images search for 66 dart there is one out there with one with a shaker. There's some under hood pics I think it's a small block. I'm putting together a 66 with a block and going with a tall max wedge scoop.
