New motor dyn testing, what will it make? #1683306
10/08/14 02:14 AM
10/08/14 02:14 AM
Cab_Burge Offline OP
I'm going to the dyno tomorrow to get the new bracket motor mounted up and ran for a short time to make sure it is ready to flog on Thursday morning It is a 440 block bored to 4.350, 4.300 stroke , 505 C.I. 440-1 ported heads with Indy 1.5 rockers, solid roller cam with 270 ish duration at .050 with .675 net lift at the retainers, 12.60 to 1 compression, 440-2 intake adapted to a 1050 Dominator, big dyno headers and so on. Nothing exotic I'm hoping for 750 + HP and 700 Ft lbs + on the torque on race gas, I will try my E85 Dominator carb and the local E85 mix to see what that will do Post away, if you so desire, no prizes for the most accurate guess
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683307
10/08/14 02:43 AM
10/08/14 02:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you have a flow sheet Cab? Just curious but I would hope it would meet your goal.
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683308
10/08/14 07:25 AM
10/08/14 07:25 AM
gregsdart Offline
gregsdart  Offline
I think your estimate is spot on. That is what I would have guessed. Any particular reason for the short duration/moderate lift cam? (longevity?)
Re: New motor dyn testing, what will it make? [Re: gregsdart] #1683309
10/08/14 08:22 AM
10/08/14 08:22 AM
Q
Quicktree Offline
Quicktree  Offline
Q
if you can't get 750hp out of 505ci and ported indy' something be wrong. heck we can do that with SB's
Re: New motor dyn testing, what will it make? [Re: Quicktree] #1683310
10/08/14 09:05 AM
10/08/14 09:05 AM
I bet best HP at 40 degrees total timing
Good Luck!!
Re: New motor dyn testing, what will it make? [Re: Quicktree] #1683311
10/08/14 09:46 AM
10/08/14 09:46 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
lol
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: New motor dyn testing, what will it make? [Re: Ian] #1683312
10/08/14 05:27 PM
10/08/14 05:27 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I say 720hp 670tq.unless it is on that happy dyno again. very similar to my 500" builds. Good luck with the indy rockers. I have broke more of them than I can count.......
these were used on a motor just like yours.....
Re: New motor dyn testing, what will it make? [Re: Old School] #1683313
10/08/14 06:22 PM
10/08/14 06:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I say 720hp 670tq. very similar to my 500" builds. Good luck with the indy rockers. I have broke more of them than I can count.......
they were not designed for high spring pressure, at least they don't act like it. i have broken more than a few myself before switching
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683314
10/08/14 06:45 PM
10/08/14 06:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I used to run a Crane roller cam the same size in my 451.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683315
10/09/14 09:37 AM
10/09/14 09:37 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
780 hp and just a tad over 700 ft lbs..
Re: New motor dyn testing, what will it make? *DELETED* [Re: Cab_Burge] #1683316
10/09/14 02:16 PM
10/09/14 02:16 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Post deleted by Drummer 1-3/4
Re: New motor dyn testing, what will it make? [Re: BradH] #1683317
10/09/14 06:54 PM
10/09/14 06:54 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
I'll guess 758hp @6100 and 689tq @ 4850.
Re: New motor dyn testing, what will it make? [Re: moparmanjames] #1683318
10/10/14 01:44 PM
10/10/14 01:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: New motor dyn testing, what will it make? [Re: Quicktree] #1683319
10/10/14 03:21 PM
10/10/14 03:21 PM
I'm waiting on the dyno shop to e mail me copies of what it did, his shop printer cartridge was dried up It didn't do as well as I had hoped, I will call him and ask if his MSD had a RPM chip in it as this motor was done at 6500 RPM The last stroker motor I built with similar parts like this one made peak HP at 7200 RPM I saw a little over 700 HP on the gauges(around 680 on the torque) but this dyno doesn't always print what you see One of the other dyno shops I use to use in SO CA had a Super Flow dyno that would do the same thing so they sold it and bought a DTS, it never did that The sampling rate, 10 times a second versus 100 times a second, was the differences according to them The customer was there and he likes it so that is what realy counts I'll post the actual results once I get them
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683320
10/10/14 07:32 PM
10/10/14 07:32 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
all of my 500" motors are done around 6500. I use solid rollers in all of them. 13.1 compression. 272/276@.050 .650"........
here is a dyno sheet showing it peaking around 6500
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683321
10/10/14 07:54 PM
10/10/14 07:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I have been telling you for 10 years, you dont need to spin them to 7500. I shifted mine at 6700, usually even less. I'm sure it will run good
Re: New motor dyn testing, what will it make? [Re: Cab_Burge] #1683322
10/10/14 09:04 PM
10/10/14 09:04 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I had mine rebuilt as a pump gas engine...had the "BIG" roller re-cut with a total of .689/.692 and .264/.268 @ .050 durations...10-1 compression, 499"..686 hp @ 7200 with more in it...torque was a tick under 700...this was in a rich condition and with 93 octane....
and 36* locked out, 1050 HP Dominator a bit rich..black
so what Im saying, perhaps more tune...???
Re: New motor dyn testing, what will it make? [Re: smokinwoody] #1683323
10/11/14 03:17 AM
10/11/14 03:17 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Hi Cab,
Where did you dyno this one? I'm interested to hear all of the details.
Glad it ran good!
ps Black car is in the shop getting prepped!
Re: New motor dyn testing, what will it make? [Re: Jeremiah] #1683324
10/16/14 12:10 AM
10/16/14 12:10 AM
Las Vegas NV
Las Vegas NV
Any updates CAB?
Re: New motor dyn testing, what will it make? [Re: moparmanjames] #1683325
10/16/14 02:00 AM
10/16/14 02:00 AM
No more updates, there was a fuel delivery problem with the dyno fuel system so no real good results Maybe next time The customer was in a hurry and took the motor home He was content with those results I had higher hopes due to the parts and compression that motors has You can only make as much power as the motor will suck in fuel and air, to much air with not enough fuel can kill the motor I am going to do a complete leak down on the motor before it goes back into the car, if it is hurt I will bring it back to my shop and take care of it
