New motor dyn testing, what will it make?
#1683306
10/08/14 02:14 AM
10/08/14 02:14 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
I'm going to the dyno tomorrow to get the new bracket motor mounted up and ran for a short time to make sure it is ready to flog on Thursday morning It is a 440 block bored to 4.350, 4.300 stroke , 505 C.I. 440-1 ported heads with Indy 1.5 rockers, solid roller cam with 270 ish duration at .050 with .675 net lift at the retainers, 12.60 to 1 compression, 440-2 intake adapted to a 1050 Dominator, big dyno headers and so on. Nothing exotic I'm hoping for 750 + HP and 700 Ft lbs + on the torque on race gas, I will try my E85 Dominator carb and the local E85 mix to see what that will do Post away, if you so desire, no prizes for the most accurate guess
Re: New motor dyn testing, what will it make?
[Re: Quicktree]
#1683310
10/08/14 09:05 AM
10/08/14 09:05 AM
I bet best HP at 40 degrees total timing Good Luck!!
[Re: Quicktree]
#1683311
10/08/14 09:46 AM
10/08/14 09:46 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
if you can't get 750hp out of 505ci and ported indy' something be wrong. heck we can do that with SB's
lol
[Re: Ian]
#1683312
10/08/14 05:27 PM
10/08/14 05:27 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I say 720hp 670tq.unless it is on that happy dyno again. very similar to my 500" builds. Good luck with the indy rockers. I have broke more of them than I can count....... these were used on a motor just like yours.....
[Re: Old School]
#1683313
10/08/14 06:22 PM
10/08/14 06:22 PM
Quicktree
I say 720hp 670tq. very similar to my 500" builds. Good luck with the indy rockers. I have broke more of them than I can count....... these were used on a motor just like yours.....
they were not designed for high spring pressure, at least they don't act like it. i have broken more than a few myself before switching
[Re: Cab_Burge]
#1683314
10/08/14 06:45 PM
10/08/14 06:45 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I used to run a Crane roller cam the same size in my 451.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: moparmanjames]
#1683318
10/10/14 01:44 PM
10/10/14 01:44 PM
Quicktree
[Re: Quicktree]
#1683319
10/10/14 03:21 PM
10/10/14 03:21 PM
Cab_Burge
I'm waiting on the dyno shop to e mail me copies of what it did, his shop printer cartridge was dried up It didn't do as well as I had hoped, I will call him and ask if his MSD had a RPM chip in it as this motor was done at 6500 RPM The last stroker motor I built with similar parts like this one made peak HP at 7200 RPM I saw a little over 700 HP on the gauges(around 680 on the torque) but this dyno doesn't always print what you see One of the other dyno shops I use to use in SO CA had a Super Flow dyno that would do the same thing so they sold it and bought a DTS, it never did that The sampling rate, 10 times a second versus 100 times a second, was the differences according to them The customer was there and he likes it so that is what realy counts I'll post the actual results once I get them
[Re: Cab_Burge]
#1683320
10/10/14 07:32 PM
10/10/14 07:32 PM
Old School
Virginia Beach, VA
all of my 500" motors are done around 6500. I use solid rollers in all of them. 13.1 compression. 272/276@.050 .650"........
here is a dyno sheet showing it peaking around 6500
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Cab_Burge]
#1683321
10/10/14 07:54 PM
10/10/14 07:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have been telling you for 10 years, you dont need to spin them to 7500. I shifted mine at 6700, usually even less. I'm sure it will run good
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
