frozen brake drum #1681889
10/04/14 02:01 PM
10/04/14 02:01 PM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
Took the hub/drum assembly off the A100 and can't get the drum free from the hub. I want to change the LH thread studs to RH threads. I used PB blaster and a 20 ton press and no luck. What else can I try?
Re: frozen brake drum [Re: poison_ivy] #1681890
10/04/14 02:14 PM
10/04/14 02:14 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Did you cut the swages off the studs ? (Assuming they are still there)
Re: frozen brake drum [Re: poison_ivy] #1681891
10/04/14 02:26 PM
10/04/14 02:26 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The pic below shows the studs before and after swaging, if you don't remove the swaging before removing the studs the hub can be damaged.
Re: frozen brake drum [Re: OzHemi] #1681892
10/04/14 02:26 PM
10/04/14 02:26 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
I had the same problem on a 67 Barracuda.Tried a press with no luck,ended up giving it a good wack on the end of the hub with a post maul and finally cracked it loose.
Re: frozen brake drum [Re: John_Kunkel] #1681893
10/04/14 02:30 PM
10/04/14 02:30 PM
Rio Linda, CA
Rio Linda, CA
Here's the cutter used to remove the swages, an automotive machine shop might have one and Goodson sells them.
Re: frozen brake drum [Re: wannadrag] #1681894
10/04/14 04:57 PM
10/04/14 04:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yeah you need to cut the swedges.Id almost say if you got carried away with the press the hub might be bent.If its bent good luck.It will need replaced.Had a brake mechanic try what you did once.New drums fixed what he did along with the hubs.Rocky
Chrysler Firepower
Re: frozen brake drum [Re: therocks] #1681895
10/05/14 01:02 AM
10/05/14 01:02 AM
Visalia, CA.
P
P
Visalia, CA.
Had no idea about the swaged studs, but a bigger hammer took care of it! Now I have to get new studs, and I want to change the LH for RH. Is there a particular part # I should ask for. Do the studs HAVE to be swaged when I install new ones?
Re: frozen brake drum [Re: poison_ivy] #1681896
10/05/14 10:04 AM
10/05/14 10:04 AM
moparx Offline
moparx  Offline
before you use that hub again, put it back on the truck and check the runout of the hub to drum face. if it's bent, you will be not happy after you install your new drum and studs , then find out it's bent...........
Re: frozen brake drum [Re: moparx] #1681897
10/05/14 11:07 AM
10/05/14 11:07 AM
Lexington NC
twinscrew698 Offline
Lexington NC
Back in the day shops used this to remove and install!
Click on the PDF file above^
8291294-Bendix_73911.pdf (340 downloads)
Re: frozen brake drum [Re: twinscrew698] #1681898
10/05/14 11:37 AM
10/05/14 11:37 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: frozen brake drum [Re: GomangoCuda] #1681899
10/05/14 05:01 PM
10/05/14 05:01 PM
Lexington NC
Lexington NC
Thanks i think i fixed it,Had to use another program to flip it and re-save it!
Although you have to go into your download folder to open it,at least i did!
Re: frozen brake drum [Re: poison_ivy] #1681900
10/05/14 05:19 PM
10/05/14 05:19 PM
Rio Linda, CA
Rio Linda, CA
You can lead a horse to water but.............
Re: frozen brake drum [Re: John_Kunkel] #1681901
10/05/14 05:53 PM
10/05/14 05:53 PM
Visalia, CA.
P
P
Visalia, CA.
Thanks everyone for the info. I did get the drums and hubs separated. I don't think the drums are damaged, but I will check. Mopar obviously did some strange things a while back. Still can't figure out why they had LH & RH threaded studs. I'm for sure going to change that!
Re: frozen brake drum [Re: John_Kunkel] #1681902
10/05/14 11:32 PM
10/05/14 11:32 PM
moparx Offline
moparx  Offline
with that being said, i have had to replace many hubs over the years that had been bent by not removing the swedge on the studs. mopar was famous for using them. gm & ford, not so much. this was mainly because there was no support under the stud being removed. however, IF you got the stud out with the BFH and didn't somehow bend the hub, then you said bad words when the new studs fit really loose upon installation. why ? because upon removal, the swedgs ground the serration hole oversize on the way out. then it was either tack weld the stud to the hub, or try to find another stud that was slightly[approximately .010] larger on the spline od. than the original application. sometimes it just isn't as simple as it seems.
Re: frozen brake drum [Re: moparx] #1681903
10/06/14 12:20 AM
10/06/14 12:20 AM
Visalia, CA.
P
P
Visalia, CA.
I have never come across a swaged brake drum before. Yes the holes are slightly larger now, but is that going to be that much of a problem? I mean when your running down the road, with all lugs tightened, what could go wrong? I'm not trying to be a butt about this,but I've owned and worked on a lot of my own cars over the years, and never encountered such a thing. Why would you seriously need the studs swaged? Just wondering if it's absolutely necessary. I just thought of something, why aren't the rear drums swaged on?
Re: frozen brake drum [Re: poison_ivy] #1681904
10/06/14 01:50 AM
10/06/14 01:50 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Nothing wrong with leaving the drum loose on hub, AS LONG as the drum does not get caught on edge of stud knurl when wheel gets snugged down.
Re: frozen brake drum [Re: poison_ivy] #1681905
10/06/14 04:35 AM
10/06/14 04:35 AM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
The problem will rear it's head at 2 am on a dark and lonely night when your trying to remove a flat and the studs are spinning.
Re: frozen brake drum [Re: moparx] #1681906
10/06/14 11:54 AM
10/06/14 11:54 AM
Minn
SportF Offline
SportF  Offline
Minn
I have said this before here,you don't want to weld on those hardened studs (and all studs are grade 8 hardened to my knowledge). It will embrittle the head and it will fall off. In 6 months, or 6 years, it will fall off. In my case, 10 studs tack welded to hub, 7 heads came off 6 months later. Moroso studs.
Re: frozen brake drum [Re: therocks] #1681907
10/06/14 12:22 PM
10/06/14 12:22 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Not to hijack here but I am getting ready to tear my A-100 straight axle apart for the my 65 AWB car. Are the swedged studs something that was typically used and is this cutter something I need to purchase prior to disassembly? thx...
I want to stay drum brakes but was reading where the 10 x 2 1/2 drums used for a 65 Coronet spindle are also interchangeable with the A-100, and I don't recall having the swedged studs on the Coronet front drums.
...FAFO...
Re: frozen brake drum [Re: skicker] #1681908
10/06/14 07:48 PM
10/06/14 07:48 PM
Minn
SportF Offline
SportF  Offline
Minn
65 drums should be swedged also. You can get the studs out without that cutter by drilling the heads out from the back. But even with good drills and a drill press this will take some time.
