Re: B1 valve cover gaskets
[Re: a493demon]
#1680433
09/30/14 11:17 PM
09/30/14 11:17 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
guess I should ask todd if he has some in stock
You get a set of our Superformance valve cover gaskets (#3188) from Todd. If it is not THE BEST gasket you have used in that application I will GIVE YOU YOUR MONEY BACK!
For all those recommending other brands your missing the boat on a true performance gasket. Live a little , will ya
[Re: roadhazard]
#1680435
10/01/14 07:32 PM
10/01/14 07:32 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
Greg you are a true class act! And your gaskets are even that much better!
[Re: a493demon]
#1680436
10/01/14 11:17 PM
10/01/14 11:17 PM
roadhazard
Akron, Ohio U.S.A.
sound's like a deal.
You'll be living on the edge now with these "off brand" gaskets
Our business is built on referral's not advertising dollars. So everything that goes out the door is of the best quality to generate those referral's.
I appreciate your support and the support of the others who have chimed in, in support of Superformance
