B1 valve cover gaskets #1680426
09/30/14 08:51 PM
09/30/14 08:51 PM
baldwinsville new york
a493demon Offline OP
Who sell's them and who's are the best?
thanks brad
Re: B1 valve cover gaskets [Re: a493demon] #1680427
09/30/14 08:52 PM
09/30/14 08:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B1 valve cover gaskets [Re: pittsburghracer] #1680428
09/30/14 09:13 PM
09/30/14 09:13 PM
guess I should ask todd if he has some in stock
Re: B1 valve cover gaskets [Re: a493demon] #1680429
09/30/14 09:34 PM
09/30/14 09:34 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
SCE
Re: B1 valve cover gaskets [Re: Sammy] #1680430
09/30/14 09:44 PM
09/30/14 09:44 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Brad, mine are around .020/.025 thick and I have pulled the covers off 4 times or better on each side. Not sure what covers you are using, but if they are stock cast B1, a thick gasket can crack them if not careful. FYI
Re: B1 valve cover gaskets [Re: Mopar-Al] #1680431
09/30/14 09:51 PM
09/30/14 09:51 PM
Al that's what I did tonight when I was checking valve lash
Re: B1 valve cover gaskets [Re: a493demon] #1680432
09/30/14 11:06 PM
09/30/14 11:06 PM
Arizona
Chris'sBarracuda Offline
Arizona
Koffel sells a really thin one that works the best I've seen..
Just put vaseline on them and your good to go..
Chris..
Re: B1 valve cover gaskets [Re: a493demon] #1680433
09/30/14 11:17 PM
09/30/14 11:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You get a set of our Superformance valve cover gaskets (#3188) from Todd. If it is not THE BEST gasket you have used in that application I will GIVE YOU YOUR MONEY BACK!
For all those recommending other brands your missing the boat on a true performance gasket.
Live a little , will ya
Re: B1 valve cover gaskets [Re: roadhazard] #1680434
10/01/14 01:29 AM
10/01/14 01:29 AM
sound's like a deal.
Re: B1 valve cover gaskets [Re: roadhazard] #1680435
10/01/14 07:32 PM
10/01/14 07:32 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Greg you are a true class act!
And your gaskets are even that much better!
Re: B1 valve cover gaskets [Re: a493demon] #1680436
10/01/14 11:17 PM
10/01/14 11:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You'll be living on the edge now with these "off brand" gaskets
Our business is built on referral's not advertising dollars. So everything that goes out the door is of the best quality to generate those referral's.
I appreciate your support and the support of the others who have chimed in, in support of Superformance
Re: B1 valve cover gaskets [Re: roadhazard] #1680437
10/01/14 11:22 PM
10/01/14 11:22 PM
oh I have used your gaskets on my other engine and have them on the new engine. just used some VC gaskets that came with it .
Re: B1 valve cover gaskets [Re: a493demon] #1680438
10/01/14 11:29 PM
10/01/14 11:29 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I really appreciate that
We'll have to get to work on some B-1 intake gaskets for you guys. Been getting lots of requests for those.
Re: B1 valve cover gaskets [Re: roadhazard] #1680439
10/02/14 12:51 AM
10/02/14 12:51 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
pm me when you do
1.39 9.85 - 137 mph
Re: B1 valve cover gaskets [Re: a493demon] #1680440
10/02/14 10:23 AM
10/02/14 10:23 AM
ohio
top comp Offline
top comp  Offline
ohio
we use the ones Koffels sells,and we run the valves after pass,haven't seen the crew chief change one yet.
