Re: Vaccum gauge bouncing ...
[Re: stumpy]
#1679683
09/29/14 10:37 PM
09/29/14 10:37 PM
Posts: 15,472 Omaha Ne
TJP
Omaha Ne
You still haven't told us what happened when you unplugged one wire at a time which will isolate a bad cylinder in case it isn't a carb problem. Just because all the parts are new doesn't mean one couldn't have failed.
[Re: stumpy]
#1679685
09/30/14 04:31 AM
09/30/14 04:31 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
No [Edited by Moparts - Family Friendly Site - Keep it clean]'
again , thanks for nothing
[Re: ahy]
#1679686
09/30/14 04:32 AM
09/30/14 04:32 AM
JohnRR
U.S.S.A.
I wonder if its possible you got ported vacuum? Sounds silly but wouldn't hurt to check another port... maybe same one as the brake booster.
No , it's a holley carb , it was on the base.
Thanks to everyone that was helpful, it'll be a few weeks before I have the time to get back to it.
[Re: JohnRR]
#1679687
09/30/14 06:46 AM
09/30/14 06:46 AM
Posts: 523 Right here
HP2
Right here
An useful site for vacuum reading is http://www.secondchancegarage.com/public/186.cfm If you are running a hot cam things changes. It's impossible to get a steady needle at lower rpm's, so how do you determine what power valve to put in your Holley?
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
[Re: HP2]
#1679689
09/30/14 12:05 PM
09/30/14 12:05 PM
Posts: 15,487 Florida
scratchnfotraction
thanks, that was indeed an interesting read on the vac readings.
[Re: JohnRR]
#1679690
09/30/14 02:03 PM
09/30/14 02:03 PM
Posts: 32,971 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
What is your problem?. I have done nothing but try to suggest things to help and you come back with garbage aimed at me. If my advice bugs you so much then put me on ignore.
[Re: HP2]
#1679691
09/30/14 04:19 PM
09/30/14 04:19 PM
JohnRR
U.S.S.A.
Thanks I'll check it out.
As I was trying to fall asleep I remembered something that happened while turning the engine over to inspect the cam while the intake was off , it's either a head gasket or a bent intake valve.
[Re: JohnRR]
#1679692
09/30/14 05:06 PM
09/30/14 05:06 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I was poking you with a stick just for fun, You know your still the coolest right??? Ron
[Re: RJS]
#1679693
09/30/14 07:03 PM
09/30/14 07:03 PM
JohnRR
U.S.S.A.
I'm far from the coolest ...
